Kyosho MP10 Thread
#796
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
#797
Mp10 TK12 question
Do you folks think the long shock towers and bigger shocks will be a necessary upgrade on Mp10 TK12
#799
Super Moderator
#800
Green Oil vs Blue Oil
What is the difference between the green filter oil and blue filter oil
#801
Hi guys, I just got a brand new MP-10, I haven’t driven buggy in years so I’m feeling a bit new at it lol, done a lot of truggy racing, I drive on a pretty bumpy loose track, can I get any advice on a decent setup for bumpy tracks and any upgrades that may help aswell? Right now I have 7k 5k 3K diff oils, and 600 front shock oil and 425 rear shock oil with the standard blue springs in the rear and grey in the front.
Thanks in advance for any advice 😁👍🏼
#804
https://sodialed.com/setup/N7k9jUAiGwmAcnjPlnFQ
Lee Muse
#805
you should be fine with the diffs.
less rear toe in the rear helps calm it down also.
#806
J.Whiting, would you still run 5 5 3 in diffs in new car for a loose bumpy track? Also would you run emulsion shocks and order the older caps with bleeders? Thanks..
#807
Super Moderator
yes i like 5-5-3 in low bite and 7-7-4 in high bite tracks.. i like the emulsion shocks 99% of the time unless i have big jumps or need lift on a jump face to clear a jump. i would order the IFW469 for emulsion shocks.. they seem to bleed the air pocket out better.. if you run bladders then run the kit shock or the ifw469.. the ifw469 caps are a running production change to make the top loop thicker to last longer.
#808
What would you run for pistons, oils and springs?
#809
Super Moderator
ifs002-815 blue front 1.2x8 600 or 1.3x5 550
ifs003-1015 red rear 1.3x8 500 or 1.4x5 450
#810
