Kyosho MP10 Thread >
Kyosho MP10 Thread
Like Tree81Likes
Kyosho MP10 Thread
Old 08-13-2019, 02:58 PM
  #436
Trader Rating: 21 (100%+)
Originally Posted by iplaygames View Post
what comes in the eight x kit is nothing like what the pros are using, and the quick access diffs on the x are more hard to access and a pain, you can expect a 2.0 version soon.
The mp10 platform will be around for many years, the mp9 was 9 years?
parts on kanai's car once visible are very quick to market - the eight x pros are still running proto parts from after nats to now that are not in the market yet.
That's good to know , I have noticed tlr off the podiums as of late. I've always wanted to try the inferno series though. And while I like the design of the 8ight X after seeing the issue with the steering knuckles cracking on first batch kits (which I guess they addressed).
8thwonder is offline
Old 08-13-2019, 04:34 PM
  #437
morgoth's Avatar
Originally Posted by 8thwonder View Post
I'm definitely having a hard time choosing between the MP10 and 8ight X. I am currently running a D817v2 that i grabbed on here used. I really want to build a new kit!!! decisions decisions
Get the Kyosho. The 8ight-X isnít as good as the older Losi cars.
morgoth is offline
Old 08-14-2019, 12:05 PM
  #438
Just ordered my mp10 today. Can't wait to get it!!! Any recommendations for setups? Or is box setup good. Thanks
Old 08-14-2019, 01:01 PM
  #439
some find the kit setup just a little loose but use kanai's setup on FB, bertons or cody kings easy to drive setup
If you dont just "slam " the throttle out of the cornor and pull the trigger like you should the buggy will drive very well.
iplaygames is offline
Old 08-15-2019, 08:34 PM
  #440
BIGTIME's Avatar
Trader Rating: 84 (99%+)
Kyosho America has IFW612 in stock... I just placed my order.
BIGTIME is offline
Old 08-16-2019, 04:05 AM
  #441
What's happening with the mp10 front arms?. I had tki4 for the whole time it was out and probably broke 1 arm.
Mp10 I've done at least 4 arms already from soft impacts.
Trouble is I love the geometry and corner speed in the car, which is stopping me putting the mp9 arms and a,b plates on it.
Soapy is offline
Old 08-16-2019, 05:06 AM
  #442
I donít think there is any reason you could not use the tki4 front arms. My experience with tki4 arms was that they break and take the pills and hinge pins with them and the mp10 I have seen break only broke the arm.
windellmc is offline
Old 08-16-2019, 07:18 AM
  #443
Have you tried the hard arms? Are you using aluminum or plastic caster blocks? On the tki4 I broke a lot of arms with aluminum caster blocks but never with the plastic. If you use the plastic you have to use the b revision though. I broke the kit block on a very easy crash.
Old 08-16-2019, 02:52 PM
  #444
Brian C's Avatar
Trader Rating: 30 (100%+)
Do you have a picture of the B revision? Iím assuming that it is a running change, same part number?
Brian C is offline
Old 08-16-2019, 05:53 PM
  #445
ifw468b. There is a bump of extra plastic on the bottom next to where the screw goes into the knuckle.
Old 08-16-2019, 06:27 PM
  #446
I'm using alloy 17.5 caster blocks with the insert glued in as they flog out without the old support of the top arms. I have tried plastic blocks but they don't have enough precision in the steering for my liking.
Also on the mp10 arms they are offset backwards compared to 9 arms which makes a difference in Ackerman effect and steering feel.
I'm thinking of making the old mp9 top arms fit for more support of the lower arms. Stay tuned
uDi_MP7.5 likes this.
Soapy is offline
Old 08-16-2019, 07:36 PM
  #447
Left upper arm on Right hand side to get correct sweep and all the other mp9 stuff like top deck and tower and upper arm brace. This should work really well in giving the arms and caster inserts the support they need
Soapy is offline
Old 08-17-2019, 06:03 AM
  #448
My car drives great even with the slop. There are brass bushings available now that should help with the slop.
