Kyosho MP10 Thread >
Kyosho MP10 Thread
Like Tree157Likes
Kyosho MP10 Thread
Old 06-24-2019, 09:01 AM
  #391
Hello,
what do you guys think of the mp10, My son doesn't get the right feeling in the car and is fighting to get the car prepared for astro tracks.
m.velder is offline
Old 06-30-2019, 07:20 PM
  #392
carpet Carlos's Avatar
Originally Posted by m.velder View Post
Hello,
We love the car so far
carpet Carlos is offline
Old 06-30-2019, 10:46 PM
  #393
am
We are struggeling on some tracks. Not enough rear end grip and since we need to run long upper- links front and rear, bumpy tracks with ruts and edges is not so good. This car reminds me of the MP777 witch was not so good.
30Tooth likes this.
am is offline
Old 07-01-2019, 12:27 AM
  #394
Suspended
kanai has been posting setups on FB, suggest trying some... We actually ran our tki3 a week ago, still on same pace as with other cars we run.
at club level the tki3 is still probably the best car, we've been running less rear toe with orange springs in rear with shocks leaned over a bit.
iplaygames is offline
Old 07-01-2019, 04:28 PM
  #395
I'm surprised some people say the mp10 is worse. I think it has all the stability of the mp9 but is more responsive and has more steering. That's what the old car needed in my opinion.
carpet Carlos likes this.
baumel is offline
Old 07-01-2019, 05:07 PM
  #396
Team_Orange's Avatar
Trader Rating: 19 (100%+)
Exactly what I was thinking. The old car was good no doubt but it needed refined.
Team_Orange is offline
Old 07-01-2019, 07:55 PM
  #397
Im curious what's your set up ? Mine is pretty darn good on everything I put into on so far
Old 07-02-2019, 07:53 AM
  #398
I agree. More steering and rear end is more predictable when it does slide. Seems a little more stable accelerating in general.
windellmc is offline
Old 07-02-2019, 12:26 PM
  #399
am
It is better on high grip tracks than the mp9. But, on blown out low grip tracks with ruts and edges, this car looses rear grip to fast and you loose control and spins out. It just slides to much on power even with as low as 4000 in the center diff. Yes, the car is more stable if you can be "on the gas", but when a track blows out, you need a different drivingstyle. If you hit the gas on bumps the car gets unsetteled, bumps araound and slides out. What happens is that you do not have the weight transfer rearwards and you have a problem with rear end grip.
We have a bit of work to do on the shockpistons also. We run 5x1,6 rear and 5x1,5 front. I have tried this on a high grip astro track and it gave more steering than the 1,3x8 so we need to go back to 1.3mm pistons.
We need to run long upper links to get the stability in the car. What happends then is that you have to little camber gain and the car handels ruts, bumps and loose tracks worse.
If some one knows what other diffs can fit the car, i am looking to go underdrive at the rear end.
I am amazed to see that someone think you can throw a pro setup on a car and make it work on your track....
There is a reason pros do not like this car so much. Must be first time ever a Kyosho have not been in a US nats finale since the 90`s
Morpheus1289 likes this.
am is offline
Old 07-06-2019, 05:17 PM
  #400
My two cents for bumpy tracks and a less than solid rear end I consider the following:
go lighter rear spring: blue to orange. I’d also change the front to grey to blue to keep the balance.
lighter rear sway bar or remove it. I’d also consider lighter/remove front sway bar too depending on how bad the track is.
reduce the rear toe in to the minimum. If the car is bouncing and pitching then 3.5 degree toe on one side without the countering 3.5 on the other side, it’s going to steer the rear.
lay the rear shocks down if not getting enough compliance from the arms
lighter rear shock oils. Again the idea is the unsprung weight is to take the bump not the whole buggy.
banana rt and Morpheus1289 like this.
Matty A is offline
Old 07-09-2019, 04:31 PM
  #401
chro's Avatar
Hi,
First time posting here in the forum.
I've just finished putting together MP10(painted body less)--so much fun building the kit.
Since I don't have any paints/supplies or ideas for good paint job, I'm trying to get a body from a RTR kit.
I wonder if a body from the TKI3, TKI4 or any other will fit MP10.
Any input would be appreciated.
Thanks in advance!
-Ken
chro is offline
Old 07-09-2019, 07:07 PM
  #402
Originally Posted by chro View Post
Hi,
Thanks in advance!
-Ken
tki3 bodies definitely fit. The engine sits slightly further forward so watch when you cut out the engine hole. It is only a couple of mm difference.
Old 07-11-2019, 01:11 PM
  #403
chro's Avatar
Awesome Thank you again!
chro is offline
Old 07-14-2019, 12:34 AM
  #404
MikaR's Avatar
Congrats to Riccardo Berton and Kyosho winning the Euros. Was he driving mp10 ? Did they have the electric class ?
MikaR is offline
Old 07-14-2019, 12:38 AM
  #405
Suspended
yes, MP10. the best thing is having Cody king back running, he will be able to provide some very good average joe setups like he did with the mp9 platform.
MikaR likes this.
