Kyosho MP10 Thread >
Kyosho MP10 Thread
Like Tree73Likes
Kyosho MP10 Thread
Old 04-25-2019, 09:21 AM
  #376
am
They are not released yet. Kanai only showed them on FB
am is offline
Old 04-25-2019, 10:49 AM
  #377
Has anyone ran the mp9 c-d blocks & mp9 Arms on the mp10 ?
Ricardo_d99 is offline
Old 04-26-2019, 04:25 PM
  #378
So what set ups are the boys running on smooth low bite tracks at the moment ?
im currently using my Mp9 set up and the standard 5/5/3 diffs
91junior is offline
Old 05-11-2019, 02:22 PM
  #379
Morpheus1289's Avatar
For those of you who are using an electronic switch mounted to the transponder tray, where are you mounting your transponder? Iím trying to find the best alternative spot to mount my MyLaps transponder on this chassis. Thanks for your help!
Morpheus1289 is offline
Old 05-11-2019, 03:55 PM
  #380
underneath the switch
91junior is offline
Old 05-12-2019, 05:37 AM
  #381
Do you mean on the underside of the transponder tray? Loose or secured with screw?
Any way way you could take a picture to show me what you mean?
Old 05-12-2019, 10:48 AM
  #382
R/C Tech Elite Member
houston's Avatar
Trader Rating: 96 (100%+)
inside rcvr box .... use lots of foam and padding to make sure things are protected ....
token and Morpheus1289 like this.
houston is offline
Old 05-12-2019, 03:51 PM
  #383
secured in the same spot as per the manual but underneath. Then switch on top
91junior is offline
Old 05-14-2019, 09:09 PM
  #384
banana rt's Avatar
seen many mp10 beefed front arms break on my local track,, (im still using mp9),
i think new beefed/solid arms makes less impact resistance compared to ordinary arms,,
banana rt is offline
Old 05-15-2019, 12:29 AM
  #385
hey brus,
Iíve broken a few MP10 arms. Iíve never broken a MP9 arm. I ran both cars on the same track and same temp. I threw me MP10 arms in the bin and put some MP9 arms on my MP10. Car is much more reliable now and after a few weeks of running no more broken arms.
91junior is offline
Old 05-15-2019, 01:05 AM
  #386
So the million $$ question.
Is the MP10 that much better than a very good MP9 TKI4/3.
I've been running MP9's since TKI2 came out and I only recently got a 10th anniversary model but I would love an honest answer off guys who are usually a second or 2 lap time off the pro's.
Soapy is offline
Old 05-15-2019, 11:32 AM
  #387
am
On the arm "issue"; there were broken front arms on the TKI series until you could buy hard arms for the TKI3, after that there were no issues. I suggest get the hard MP10 arms as i belive that will solve the "problem".
am is offline
Old 05-15-2019, 11:36 AM
  #388
houston's Avatar
i broke one arm , it was well deserved as i hit Greg Degani as he was upside down in front of me ..... ugggh
that was a kit arm , i havent broke an arm that is not a kit arm though , i did some pretty spectacular crashing at silver state as well ..... lol
houston is offline
