Kyosho MP10 Thread >
Kyosho MP10 Thread
Like Tree71Likes
Kyosho MP10 Thread
Old 04-11-2019, 12:37 AM
  #361
R/C Tech Elite Member
houston's Avatar
Trader Rating: 96 (100%+)
Messed up one thing on setup sheet ....ooops
Originally Posted by klithgow416 View Post
Car looks good. Seen a brand new one for sale in the for sale section.
some racers are brand whores ...... switch brands on the drop of a hat .
change their minds constantly .....some just like to build the cars and lose money .... craziness i say
Matty A likes this.
houston is offline
Old 04-11-2019, 06:34 PM
  #362
Which way did you run the steering rack? You are showing both on the sheet.
windellmc is offline
Old 04-11-2019, 11:14 PM
  #363
banana rt's Avatar
how well m2c shock pistons improve suspension/handling compares original kyosho one
banana rt is offline
Old 04-14-2019, 03:20 PM
  #364
Just wondering - is the alloy servo saver, alloy rear hubs and alloy front caster blocks the same as the MP9 TKI4 ?
91junior is offline
Old 04-15-2019, 12:00 AM
  #365
am
Front castorblocks and alu servosaver is. The uprights are new.
am is offline
Old 04-17-2019, 10:53 AM
  #366
houston's Avatar
the sheet auto fills both ...... im running centered on acketman plate kingpin ...... which is plate with offset forward and 3rd hole back
houston is offline
  #367
houston's Avatar
they are pretty much the only pistons i run anymore .....
houston is offline
Old 04-17-2019, 03:04 PM
  #368
whatís your go to m2c piston and oil for low bite small bumps in the track?
91junior is offline
Old 04-18-2019, 09:56 AM
  #369
houston's Avatar
8 x 1.4 oring v2
30w rear
40w front
or if warmer
32.5w rear
42.5w front
you must drill yourself
houston is offline
Old 04-19-2019, 10:27 AM
  #370
sn47som1 is offline
Old 04-19-2019, 11:42 AM
  #371
houston's Avatar
Originally Posted by sn47som1 View Post
Hey guys a couple things I need help on if you could:
1. after installing my M2C front anti dive system on my buggy prd # M2C2925, there is a ton of play now forward and backward in the lower a arms. Can you link me with some spacers or shims or washers that will work with the m2c tapered hinge pin? Thank you
2. Do you know where I can find upper shock mount screws that are longer than the factory ones? I need some more screw length to tighten down the end nuts more. Thank you
kyosho has the 4mm arm spacer washers .... is this on an mp10?
www.monsterbolts.com
houston is offline
Old 04-22-2019, 08:02 AM
  #372
Thanks, it's on a tki4. I went with the Kyosho hinge pin spacers.
sn47som1 is offline
Old 04-23-2019, 09:09 AM
  #373
Does anyone know if I can use the MP10 body on the MP9
moisesing is offline
Old 04-23-2019, 09:12 AM
  #374
I was fitting my center diff the other day in the mount and noticed a lot of side to side play. I don't mind just a little bit of play but this is way too much. I linked a shim set below. Are these what I use to shim the front center rear diffs? Also may be an obvious question but how do I shim the diff (outer bearings) when the notches in the diff cases fit the bearings perfectly. There's no room for shims. I tried shimming the front diff the other day but the diff seated in the case like a glove. What am I missing? I tried seating it with 1 shim on ring side and it wouldnt fit, I almost bent the shim trying to seat the diff. Is it supposed to be that tight fitting with shims?
https://www.amainhobbies.com/kyosho-...yo96772/p37363
sn47som1 is offline
Old Yesterday, 02:30 AM
  #375
Been looking around. Has anyone got the alloy rear hubs in stock ? Found the fronts from kyosho japan but canít seem to find the rears
91junior is offline
