Hi new here need some help >
Old 10-25-2018, 04:55 PM
Post Hi new here need some help
Hi new here i use to be in to rc as a kid I'm now bit older and bought my self another one Hyper 7 now i know the person who had it before had it running when he put it away years ago and he messed with the tune of it so i bought it off him and im so stuck on how to tune them again my problem is when you start it it is trying to move off by it self and reving high if lifted iff ground anyway im after some help on how have pepole set theres up i have 20% nitro and 20% nitro both new also fitted new glow plug so al good there
Bertb1997 is offline
Old 10-25-2018, 05:01 PM
savage24x's Avatar
"the engine tuning bible"
savage24x is offline
Old 10-25-2018, 05:26 PM
Thanks dude ill give that a read
Old 10-25-2018, 05:50 PM
https://youtu.be/t65WgtA0OJI
https://youtu.be/iCfb5AVyKBw
https://youtu.be/RrIulwnDiWQ
watch all these and study them. I learned tuning from that lutz tuning video. Reason I put the other 2 carb setup videos is cause you need the carb set properly before you can tune
jersey is offline
Old 10-26-2018, 04:52 AM
Hi thanks for them videos but im having no luck my gap is set it 1mm cap in carb yet when i start it it revs like mad i seem not have any luck with this car
Old 10-26-2018, 06:42 AM
Idle gap is too wide. Start at .5mm.
Cardiak is offline
Old 10-26-2018, 07:33 AM
ill try that if not i give up and go brushless
Old 10-26-2018, 01:45 PM
May need to richen the needles too. It’ll bring the idle down.
Jcharger13 is offline
Old 10-27-2018, 07:29 PM
stick with it. I know it can be discouraging in the beginning. Definitely read up and watch YouTube vids. They will help tremendously!
Evoking1230 is offline
Old 10-27-2018, 10:28 PM
Yea learning nitro is patience. Also make sure engine has good compression no compression can lead to having a not stable idle.
When you push flywheel on bottom is there resistance. If it's easy to fully push it around and don't feel any resistance the engine doesn't have compression. Another test is when engine is out of car hold it by the flywheel if the engine can't support its weight at all and rolls over right away then compression is low.
Watch those videos I sent. I know there long but setup with a nitro car takes time setting up then takes time to find the tune and really takes time to learn it. I would tune and be ok at it. But I really learned a lot after that lutz tuning video. It helped me understand how to tune but linkage and carb opening are key to.
Maybe make a video of it. It's hard to tell you what to do over the internet also check your clutch shoes and bearings If there in good shape. Broken clutch spring or blown bearing can lead to the clutch being engaged leading to the car driving without gassing it. Linakage not set right can also do that. Set up is key.
If you were close by I'd give it a look for you
jersey is offline
Old 10-29-2018, 05:49 AM
I used to always want nitro. I did R/C as a kid and remembered the 2-5 minute battery life, so discouraging when you are young and just want to play. Good luck tuning, hope you get it working! If not, brushless and batteries this days aren't bad either.
bob_pdx is offline
