Like Tree20Likes
Mugen Seiki MBX8T
Old 12-11-2018, 07:09 PM
  #46
Originally Posted by jmackani View Post
If you did not notice a difference then I can only assume you did not mess with the diff fluids too much to get them to work. There is a difference but I would not say it is as drastic as what it shows in the buggies. In addition I watched many guys pull them out before they were even in long enough to get broken in.
I didnít say there was no difference just that it is not worth the money when there is a new truck with basically the same diffs in it. The money is better spent on the new platform.
The point of the ht diffs was to get more oil so they would be more consistent and give more drive out of corners. A kyosho front or rear diff holds like twice the oil of the smaller Mugen diffs.
windellmc is offline
Old 12-12-2018, 08:51 PM
  #47
Rc Collaborativ's Avatar
I interviewed adam drake about this 8t and got a good explanation about the differences of the new truggy
Rc Collaborativ is offline
Old 12-22-2018, 05:42 PM
  #48
About to start my build. Any tips on the build ?
also does anyone have a good base set up for low to med bite tracks ?
cheers
91junior is offline
Old 12-22-2018, 10:29 PM
  #49
mtbkym01's Avatar
Trader Rating: 26 (100%+)
cheers
if you havenít built a Pillow Ball Mugen before, just take your time when putting in the alloy caps into the hubs to ensure you donít cross thread them. Also, install the spring collars on the Shock bodies from the top, rather than the bottom, and use a bit of green slime or tiny amount of grease or shock fluid on the o ring thatís inside the collars, to ensure they donít get damaged by the threads.
Iíd start with the box set up, and modify from there if you have too.
Enjoy the build, itís a beautiful kit to build
cheers
mtbkym01 is online now
Old 12-30-2018, 02:30 AM
  #50
cheers
I ended up using Caseyís set up I got off him. However I used an alloy servo saver. Truck is heaps dialled on low medium bite rough track. Thanks for your tips, went together a breeze
mtbkym01 likes this.
91junior is offline
Old 02-24-2019, 11:42 AM
  #51
Default Mugen MBx8T
Whatís up Mugen junkies who had the new truggy? Let me hear your pros cons and if itís worth the heavty price tag?
mattythegreat is offline
Old 02-24-2019, 11:48 AM
  #52
1/8 IC Fan's Avatar
Trader Rating: 91 (100%+)
We already have a thread: Mugen Seiki MBX8T
may get some insight there.
mattythegreat likes this.
1/8 IC Fan is offline
Old 02-25-2019, 05:19 AM
  #53
8ight T 4.0 or Mugen MBX8T ? What you think?
Old 02-25-2019, 08:25 AM
  #54
UK.hardcore's Avatar
Mugen is 10 times better then losi crap.
UK.hardcore is offline
Old 02-25-2019, 10:22 AM
  #55
the mugen is a way newer truck, the Tlr is a older truck so some parts you might wanna update to some newer upgraded options. I have a Tlr but it has upgraded parts but on it and I like it a lot the way it drives. I never tried the mugen 8t so canít speak on it but it looks like a good truck. If your buying a new car to start racing Iíd go with mugen cause it just came out and youíll have a newer model and not a older Tlr model that will probably see a revision in maybe a year.
jersey is offline
Old 02-27-2019, 07:43 PM
  #56
How has the durability been thus far?
jdsand5 is offline
Old 02-28-2019, 02:12 PM
  #57
Trader Rating: 20 (100%+)
Mugen all day. T 4.0 is way too outdated.
MX304 is offline
Old 03-03-2019, 10:13 AM
  #58
where are all the setup sheets for the truggy? Anyone have one?
Old 03-09-2019, 06:07 PM
  #59
The kit setup is really good in my opinion. I changed nothing except for adding a 50 gram weight to the rear. This is the best all around performing truck I've ever driven.
klithgow416 is offline
Old 05-14-2019, 01:45 PM
  #60
Default New mUgen Truggy what motor?
Got the itch for nitro, I have a Mugen WE i just got doing a OS Adam drake motor in that with a 2090 pipe. I want to do a truggy build aswell and race that even tho at my local track they lump nitro truggy with E truggy . What OS motor do you guys suggest I want to do something different then my adam drake edition. What would be the best option you think?
RClos17 is offline
