Like Tree20Likes
Mugen Seiki MBX8T
Old 12-04-2018, 02:47 AM
  #31
UK.hardcore's Avatar
plastic as a starting point.
UK.hardcore is offline
Old 12-05-2018, 11:03 PM
  #32
cHAmpa's Avatar
Trader Rating: 32 (100%+)
Originally Posted by criss2115 View Post
Can someone please make up an editable setup sheet and post. Thank you in advance.
Here is one for the MBX8T Nitro:
File Type: pdf
cHAmpa is offline
Old 12-06-2018, 12:38 AM
  #33
mtbkym01's Avatar
Trader Rating: 26 (100%+)
Default This kit is next level from Mugen
Best Mugen Build Ive ever done, and Ive built a few
Evoking1230 and FastPete like this.
mtbkym01 is offline
Old 12-06-2018, 05:44 AM
  #34
What makes it next level compared to the 7TR?
Cardiak is offline
Old 12-06-2018, 12:23 PM
  #35
mtbkym01's Avatar
the drivetrain is smooth as butter, before even being run in, and then the small things like steering posts key into the chassis. The arms also feel higher quality.
mtbkym01 is offline
Old 12-06-2018, 04:15 PM
  #36
Yeah. I need to upgrade my diffs to HTD. My 7tr still has some resistance in the drivetrain. What's needed to fit the arms to a 7tr?
Cardiak is offline
Old 12-06-2018, 05:18 PM
  #37
Just buy the new truck. The htd diffs in the 7tr are no smoother than the small diffs. If you want to use the new rear arms you will need suspension blocks from the 7r buggy. The down stop screws probably wont hit the chassis so they wont work either. Front arms should bolt on but you will also need the uppers, hubs, driveshafts, and camber/steering links from the new truck. ***The new arms are longer.*** They changed almost all the parts except shocks, rear hubs, engine mount, fuel tank, and steering rack. Center driveshafts and center diff (47t htd) are the same too. The old body and wing fit.
windellmc is offline
Old 12-06-2018, 05:21 PM
  #38
Originally Posted by windellmc View Post
Has anyone built one and can tell if 7t bodies fit?
I confirmed the 7t stock body goes right on. Thanks Mugen for not changing that seriously.
For anyone thinking about buying 8t parts to upfit their 7tr: Just about everything else changed.
Old 12-06-2018, 09:52 PM
  #39
Buying a new one isn't an option for me since my 7TR is basically new. Just out of curiosity, what makes the 8T diffs smoother than the 7tr HTD?
Cardiak is offline
Old 12-07-2018, 07:40 AM
  #40
FastPete's Avatar
Trader Rating: 44 (100%+)
Looks great! Were excited to be stocking Mugen now. I really need to put one together for myself for the experience.
mtbkym01 likes this.
FastPete is offline
Old 12-07-2018, 09:51 AM
  #41
The ring and pinion are different cut and the 8t pinion will not fit in the 7t.
Old 12-11-2018, 06:40 AM
  #42
jmackani's Avatar
Trader Rating: 14 (100%+)
The HTD's were not really meant to smooth out the drivetrain. The smaller pinion bearing in the rear changed that more. The HTD's are about gaining acceleration by changing the size of the gears internal to the differential and the 7TR has its own set of HTD's that can still be utilized for that.
jmackani is offline
Old 12-11-2018, 12:28 PM
  #43
Having ran a 7tr with both regular and ht diffs, save the $150 for an 8t.
Old 12-11-2018, 01:42 PM
  #44
Well, I may have a 7TR for sale if that's the case..
Cardiak is offline
Old 12-11-2018, 04:40 PM
  #45
jmackani's Avatar
If you did not notice a difference then I can only assume you did not mess with the diff fluids too much to get them to work. There is a difference but I would not say it is as drastic as what it shows in the buggies. In addition I watched many guys pull them out before they were even in long enough to get broken in.
jmackani is offline
