High vs. low wing mount. >
Like Tree8Likes
Old 10-12-2018, 12:12 AM
  #16
30Tooth's Avatar
Originally Posted by rcbuggy88 View Post
There is downforce. It does matter and does make a difference.
Please quantify it.
Last edited by 30Tooth; 10-12-2018 at 05:32 AM. Reason: Grumpy being grumpry. Sorry.
30Tooth is offline
Old 10-12-2018, 05:11 PM
  #17
rcbuggy88's Avatar
Not exactly quantifiable but when you have the wing, the car is quite a bit more stable and get more rear grip. Also, you nosedive without one.
rcbuggy88 is offline
Old 10-13-2018, 02:36 PM
  #18
30Tooth's Avatar
How much of it can be attributed to weight? The shape isn't aerodynamic too, nor is it fed right. The flat part serves as a rudder/elevator nothing more than it can be attributed to aero work.
30Tooth is offline
Old 10-17-2018, 10:38 AM
  #19
You yourself said the wing helps with the attitude of the car in the air, and I agree it does. So the wing helps and does something. On slow parts of the track, it is not doing anything. At high speeds I don't notice a difference with it high or low, but there is a difference when it is not on there at all.
largeorangefont is offline
Old 10-18-2018, 12:43 AM
  #20
30Tooth's Avatar
I have a couple sacrificial wings, will remove the curved section and see what's the difference between a normal and a straight one.
petersen114 likes this.
30Tooth is offline
