Spec tire - how to make it softer? >
Like Tree5Likes
  • 4 Post By Roelof
  • 1 Post By UrabusDenis
Old 08-22-2018, 01:13 PM
Default Spec tire - how to make it softer?
Hi guys, i am going for an event that will run a spec tire in a medium compound, its an outdoor clay track.
i would like to know whats the best way to soften up to a soft or super soft?
i heard about applying WD40 does anyone have any insight on this or if traction compounds will work better and the process of applying these?
many thanks
akshayp14 is offline
Old 08-22-2018, 01:37 PM
Roelof's Avatar
The goal of a spec tire is to use them as they are, no treatment or else they are not spec tires anymore.
HaulinBass, Donat, dtr and 1 others like this.
Roelof is offline
Old 08-23-2018, 10:46 AM
You may want a harder tire on an outdoor track.
windellmc is offline
Old 08-24-2018, 04:45 PM
MaricopaAgent's Avatar
Trader Rating: 28 (100%+)
liquid wrench, put them in a ziplock bag and put in the sun for an hour or two.
MaricopaAgent is offline
Old 08-25-2018, 01:11 AM
UrabusDenis's Avatar
As Roelof said, pretty sure it's not meant to be treated if its spec. Check the rules, otherwise its cheating, dont be that guy
am likes this.
UrabusDenis is offline
Old 08-30-2018, 02:02 AM
there are no rules against saucing, it is a spec tire event not controlled tire.
the tires come premounted and i'd like to soften them up (in a manner that will not damage the inserts) as an option for changing track conditions
"liquid wrench, put them in a ziplock bag and put in the sun for an hour or two." ----> thanks MaricopaAgent, will try this out, im sure it will be similar to WD40?
thanks for your opinions
Old 08-31-2018, 05:44 AM
Trader Rating: 21 (100%+)
I will give u the best tip, simple green and sun light. Softens the tires right up in a few hours. I was amazed when I heard about it and to my surprise it works very good.
and u donít have to worry about someone calling you out making you out to be minipulating a spec tire, itís simple green and sun light. Case closed your welcome.
Matt Piva is offline
