Starter Box Conversion >
Old 08-21-2018, 01:03 AM
Default Starter Box Conversion
Hi, i have a robitronic starter box:
Anyone can help me stepbystep on how to convert it to lipo batteries?
Thank you
Guyon is offline
Old 08-21-2018, 01:14 AM
Thank you
change the plug to match your 4s and put in the 4s lipo...done
iplaygames is offline
Old 08-21-2018, 01:20 AM
Roelof's Avatar
If it is made for 2 Tamiya type racing packs the most simple thing is getting 2 LiPo tamiya style racing packs.
I think the better option is using 2 shorties.
Roelof is offline
Old 08-21-2018, 02:02 AM
What if i use just 1 LIPO battery, instead of using 2x7,2 i could use 1 3s? Or that wouldn't be enough?
Guyon is offline
Old 08-21-2018, 02:41 AM
a small 2200 4s will be enough for a full day, very light.
buy a 4s pack...Cut off the tamiya connector and add in what ever the battery came with and done...
DO not spend a furtune doing the whole 2 x 2s setup, its not needed and is heavy.
This is what i have and what i've recommended and they've loved it.
https://www.amainhobbies.com/gens-ac...-b1009/p581475
Old 08-21-2018, 06:42 AM
I've read to use a 3s instead of a 4s, coz the peak might burn off the starter -.-
Is that true?
PS i have a tamiya => Dean adapter, that might do it with the battery you suggested. I just need to figure out if 3s or 4s
Guyon is offline
Old 08-21-2018, 09:13 AM
UrabusDenis's Avatar
I have the same box for 3 years, on 4S. Just solder good connectors (Tamiya ones will burn) and ditch the whole plastic battery assembly, make your own for your battery. Done
UrabusDenis is offline
Old 08-21-2018, 08:57 PM
3 cell lipo with deans or x60 connectors.
token is offline
Old 08-21-2018, 11:42 PM
Like this one => https://it.aliexpress.com/store/prod...ceBeautifyAB=0
4200mah should be enough right? 5200 seems a bit overkill
Guyon is offline
Old 08-22-2018, 01:08 AM
Suspended
dual motor box? use a small 4s. if you start beating on the box because flamed car or some other bloke using it, a 3s will feel the heat with the current drain.
Be wise, use a small 4s.
Nicks mp9 is offline
