What to clean engine with? >
Like Tree3Likes
  • 1 Post By Jowers
  • 2 Post By houston
Old 08-13-2018, 10:07 AM
LoudOne's Avatar
Trader Rating: 31 (100%+)
Default What to clean engine with?
Hey folks,
Curious what you use to clean your nitro engines?
LoudOne is offline
Old 08-13-2018, 10:16 AM
On the inside or the outside?!
Alcohol (both ethanol and methanol) works very well; WD-40 cleans well, and also kerosene or mineral spirits.
I would stick with alcohol though on the inside since fuel is alcohol based.
kwhunter is offline
Old 08-13-2018, 10:21 AM
Roelof's Avatar
Simple brake cleaner
Roelof is online now
Old 08-13-2018, 10:38 AM
HaulinBass's Avatar
Trader Rating: 14 (100%+)
outside, my wife has some orange based cleaner that does a really good job with some hot water. internally i use brake cleaner and a plastic sponge if there is carbon built up
HaulinBass is offline
R/C Tech Elite Member
CBren32's Avatar
Yes! This. Don't use anything else other than brake cleaner or get Nitro cleaner from TA emerald. One or the other is all you need.
CBren32 is offline
Old 08-13-2018, 11:11 AM
JRSlash's Avatar
Cleaning gum/putty. Is pretty good. No risk of spraying anything on the bearings.
https://www.amainhobbies.com/xceed-r...103233/p173800
JRSlash is offline
Old 08-13-2018, 11:14 AM
Jowers's Avatar
I use simple green and a toothbrush. Nothing harsh needed.
savage24x likes this.
Jowers is offline
Old 08-13-2018, 01:32 PM
I use putty for the outside and nothing for the inside.. I'm one that never open his engines.... just how I do it
token is offline
Old 08-13-2018, 02:26 PM
LoudOne's Avatar
I have TA EMERALD. So I can spray the inside with it as well? Even remove glow plug and spray inside? Thanks for responding everyone 🤘
LoudOne is offline
Old 08-13-2018, 02:30 PM
Roelof's Avatar
There is no need to clean the inside unless you are using a very agressive fuel resulting in a quick rust. Brake cleaner works OK on the inside but you need to oil everything afterwards with as example afterrun oil or an assembly oil.
Old 08-13-2018, 02:33 PM
lilstewie's Avatar
The few times i have actually "cleaned the inside of the engine, I have used either a brand new spray bottle or fuel bottle (to refill your car) and some nitro fuel and just sprayed the inside out. That the the safest as it in designed to literally be going through the motor and cleans quite well.
lilstewie is offline
Old 08-13-2018, 10:28 PM
AHK
Brake cleaner for me
AHK is offline
Old 08-14-2018, 10:56 AM
houston's Avatar
Trader Rating: 96 (100%+)
denatured alcohol only ....... no residue ... no water .....
nitro fuel works as well but leaves a mess
happy motorin'
NitroVein and charvel74 like this.
houston is offline
Old 08-14-2018, 11:26 AM
CBren32's Avatar
I have TA EMERALD. So I can spray the inoside with it as well? Even remove glow plug and spray inside? Thanks for responding everyone <span class="emoji-outer emoji-sizer"><span class="emoji-inner" style="background: url(chrome-extension://immhpnclomdloikkpcefncmfgjbkojmh/emoji-data/sheet_apple_32.png);background-position:73.97179788484137% 87.95534665099882%;background-size:5418.75% 5418.75%" data-codepoints="1f918"></span></span>
Yes you can, it will work well if you have the nitro cleaner. Obviously everyone has their own products that they use, which should show you there is a vast variety of cleaning products you can use. Essentially, you just want something with no water, doesn't stick and leaves NO residue. A lot of what is suggested above is probably fine, but if you already have nitro cleaner I'd stick with that, exactly what you need.
CBren32 is offline
