Like Tree258Likes
TLR 8ightX
    Hide Wikipost
Old 03-15-2019, 09:43 PM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8ightX
Last edit by: 1/8 IC Fan
TLR Eight X
Print Wikipost
Old 11-17-2019, 03:35 AM
  #871
storr99's Avatar
Anyone have any idea when the truggy will be coming???
ryanster1999 likes this.
storr99 is offline
Old 11-19-2019, 09:38 AM
  #872
ryanster1999's Avatar
I would LOVE to know this as well!!
ryanster1999 is offline
Old 11-19-2019, 10:46 AM
  #873
Can anyone advise me on whats wrong here? When I attach the throttle arm to the horn in the correct position, it hits the servo casing. I have it on top, but its wrong, it should be on the bottom of the horn. However, my angle is perfectly straight when attached up top too. Is there any harm in running it like this? How can this be prevented? Thank you so much for any info that you guys can provide. Rctech has been a lifesaver throughout this build.
Old 11-20-2019, 04:25 AM
  #874
Trader Rating: 22 (100%+)
You could place a small washer/shim in between the horn and servo splined output shaft. Done it before. Just can be a pain to find that small of a spacer.
RandyJones is offline
Old 11-20-2019, 07:50 AM
  #875
sancho's Avatar
Trader Rating: 1 (67%+)
I used a dremel to sand off enough of the plastic and the screw so it didn't hit. Ran it all last year with no problems. I took the nub off so there is no raised area on the bottom.
sancho is offline
Old 11-20-2019, 12:43 PM
  #876
Thank you guys for the helpful info! I will attempt to find a shim that size. If I cant find one, then ill start sanding it down like Sancho recommended.
Old 11-21-2019, 02:33 PM
  #877
Trader Rating: 30 (100%+)
Does anybody knows if there's a conversion kit to turn the nitro version to electric?
madness is offline
Old 11-21-2019, 04:22 PM
  #878
Originally Posted by zebramanhc View Post
i'm also from portugal. Unfortunatly, there's only like 5 drivers using the X. I drove it all the season, if you want some setup sheets or any other opinions and setup tips, i can provide them.
Hello my friend !! Thanks very much and i Will contact you to Share info and tips!!
Thanks again
timaneli is offline
Old 11-22-2019, 01:15 PM
  #879
No. Its call the 8ight XE
nitro_mt_racer and jkurz211 like this.
token is offline
Old 11-28-2019, 11:00 PM
  #880
fiveoboy01's Avatar
Trader Rating: 17 (100%+)
You can set up throttle linkages however you want. Inline with the carb barrel and as straight a pull as possible are what you're looking for, the rest is irrelevant for the most part. There are differences in carb positioning between different engine brands and sizes, so a "one size fits all" servo linkage isn't really a possibility.
fiveoboy01 is offline
Old 11-29-2019, 01:16 PM
  #881
Originally Posted by jmoneym View Post
Anybody try the universal axles yet?
I have been wondering this too! Amain states " These driveshafts are a great alternative to the stock CVA's for particular applications. For use in the front or rear." Well what are the "particular applications"? I like the ease of use with the universals, but curious how they would effect performance. More on-demand power to the wheels? If so, id imagine it would be nice for a heavily blue grooved track. Anyone have any first hand experience?
jkurz211 likes this.
Old 12-03-2019, 11:22 AM
  #882
We run the universals in the front of the buggy. Front only. CVAs in the rear are more grip..
token is offline
Old 12-03-2019, 12:14 PM
  #883
TurnNBurn's Avatar
IIRC, one of the “In Touch with TLR” episodes where they talk about the 8ight-X discusses Universal vs. CVD in pretty good detail. David Ronnefalk also recently discussed it in one of his YouTube vlogs as it pertains to the HB, so the effects should be similar.
TurnNBurn is offline
