Like Tree308Likes
TLR 8ightX
    Hide Wikipost
Old 03-15-2019, 09:43 PM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8ightX
Last edit by: 1/8 IC Fan
TLR Eight X
Print Wikipost
Old 06-20-2018, 12:48 AM
  #61
speedy2's Avatar
slackinoff likes this.
speedy2 is offline
Old 06-20-2018, 12:49 AM
  #62
speedy2's Avatar
Nice heatsink for the brake servo..
speedy2 is offline
  #63
speedy2's Avatar
speedy2 is offline
Old 06-20-2018, 12:50 AM
  #64
speedy2's Avatar
speedy2 is offline
Old 06-20-2018, 12:54 AM
  #65
speedy2's Avatar
speedy2 is offline
Old 06-20-2018, 12:55 AM
  #66
speedy2's Avatar
speedy2 is offline
Old 06-20-2018, 10:53 AM
  #67
Kewlbug's Avatar
Trader Rating: 63 (100%+)
Seeing the latest results, I cant help but think, Is this car too stiff? I don't know much about anything, but my first impressions of the design was this thing has to be super solid. Maybe too solid. with the extended motor mount and the rear brace. I can see people cutting off the motor mount extension. There were extended motor mounts available aftermarket for the 3.0/4.0 but people do not use them much.
Kewlbug is offline
Old 06-20-2018, 11:31 AM
  #68
speedy2's Avatar
No.. that is wrong thinking: with a 3 mm chassis plate now, not 4 mm like before, the car will be MUCH more forgiving and stable in the rough and at lower speeds
I has more flex build in
and with a 3 mm chassis, if you don't have good long braces it will flex too much, perhaps break or bend after a while..
or the bell will make contact, or the center shafts could crash and bend on impact
To see also if the chassisplate has enough folded upwards sides or not..
Here the problem is happily fixed, with a nice long but plastic rear brace, even using an articulation at his base, and a longer engine mount, which is normaly an option part..
token likes this.
speedy2 is offline
Old 06-20-2018, 12:49 PM
  #69
slackinoff's Avatar
Excellent pictures.
slackinoff is offline
Old 06-20-2018, 02:28 PM
  #70
Kewlbug's Avatar
Originally Posted by speedy2 View Post
No.. wrong thinking: with a 3 mm chassis plate now, not 4 mm like before, the car will be MUCH more forgiving
and with a 3 mm chassis, if you don't have good braces it will flex too much, perhaps break or bend
or the bell will make contact, or the center shafts will crash and bend on impact
Well, I'm just throwing ideas out there. Those seem to be the major differences to me over the old car (As well as changing all the suspension geometry). Hopefully setup changes will get the car up to speed.
Kewlbug is offline
Old 06-20-2018, 02:52 PM
  #71
Up to Speed? Reno did qualify 6th overall with a BRAND NEW car. I do believe if he didn't flame out he would have finished top 5. I think you are panicking a bit for a car that has not been released yet.... Im currently running the 4.0 with the tuning chassis and alum rear brace and kingheadz extended motor mounts...With the evo springs the car is dialed on rough tracks..
token is offline
Old 06-20-2018, 02:58 PM
  #72
For me the major difference is the shock package, the radio tray, the gearboxes and center diff, straighting out the drive train, steering rack, adjustable arms with F/R shock locations. And of course the most asked for thing on the 8ight series of cars - METRIC HARDWARE....... ijs
token is offline
Old 06-20-2018, 04:27 PM
  #73
Kewlbug's Avatar
Those are all obvious improvements. I am talking about changes that may or may not have helped the car performance wise. What kind of screws it uses is irrelevant in this case.
Kewlbug is offline
Old 06-20-2018, 04:33 PM
  #74
kaptain crash's Avatar
Trader Rating: 46 (100%+)
I'm really liking the new buggy, lot of changes for the better. But sad about one thing...no universals ....out of the box stock. Most buggy's have them as stock. The K car, H B's, Tekno, XRAY, SWorkz, even...The Car...lol. Hate to spend $650 and have to add another $100+ to run universals...most tracks are bumpy here in the states.
token likes this.
kaptain crash is offline
Old 06-20-2018, 09:51 PM
  #75
ASA
ASA's Avatar
+1 on that......very surprised not to see u-joints on it....also I think it does require the longer rear brace and extended engine mount as it is now a 3mm chassis and the throttle/brake servo is floating meaning there is no full length radio tray to help stiffen the chassis behind the centre area.
token likes this.
ASA is offline
