Like Tree197Likes
TLR 8ightX
    Hide Wikipost
Old 03-15-2019, 09:43 PM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8ightX
Last edit by: 1/8 IC Fan
TLR Eight X
Print Wikipost
Old 03-11-2019, 08:49 PM
  #646
Trader Rating: 16 (100%+)
Originally Posted by dodgeguy View Post
So anyone else break a knuckle?
the aluminium spindle or plastic caster block?
Perrydog is offline
Old 03-11-2019, 09:17 PM
  #647
Trader Rating: 205 (100%+)
Spindle
dodgeguy is offline
Old 03-12-2019, 11:27 AM
  #648
No not the spindle.
token is offline
Old 03-12-2019, 05:32 PM
  #649
Trader Rating: 22 (100%+)
Spindle
Contact Horizon Hobby customer support and they will take care of you Id bet!!
RandyJones is offline
Old 03-15-2019, 11:32 PM
  #650
Anyone try the 3.0/4.0 arms, spindles and castor blocks on the front of this car? wonder if they would bolt up. Would be a nice suspension option.
All the years of running the 8ight platform never broke a front arm, spindle or castor block. Seems more durable than the X setup.
dodgeguy is offline
Old 03-16-2019, 02:10 AM
  #651
Trader Rating: 325 (100%+)
Anybody try the universal axles yet?
jmoneym is offline
Old 03-18-2019, 12:10 PM
  #652
Moderator
mxwrench's Avatar
Default 8ight X Set up Sheet from So Cal Nitro 3/16/19
TLR04007_Nitro_Buggy_BK So Cal Nitro.pdf
BK
token likes this.
mxwrench is offline
Old 03-18-2019, 04:05 PM
  #653
Attachment 1468724
BK
Thanks BK
token is offline
Old 03-19-2019, 10:50 AM
  #654
Trader Rating: 33 (100%+)
Can someone give me the Measurements on the front end for toe and camber a good set up Using calipers
mp9racer is offline
Old 03-19-2019, 12:31 PM
  #655
Officespace's Avatar
Im in the middle of my build right now and was curious to see if anyone has tried to use a King Headz extended quick change engine mount on the X? I have one on my 4.0 and was wondering if if will fit on the new chassis or if I should leave it on the 4.0 for my son and just buy the new quick change mount that was released for the X.
Officespace is offline
Old 03-19-2019, 04:36 PM
  #656
sfox1026's Avatar
I am running 1 degree of toe out and 1 degree of front camber on my buggy,
The inside measurement is 27mm for Camber. This is the measurement on the inside of the camber ends on turnbuckle
The inside measurement is 32.98mm for Toe in. This is also the measurement on the inside of the Steering Ends.
I am running the 20 degree castor blocks with the Aluminum Spindle carriers using the outside upper hole on spindle carrier and lower inside hole on shock tower.
Hope that helps!!!! Really like the new car!!!!!
sfox1026 is offline
Old 03-20-2019, 04:20 AM
  #657
Thanks that helped
mp9racer is offline
Old 03-20-2019, 10:04 AM
  #658
Does anyone know if they will include the 8XE front shock tower with the 8X
Chris Reilly is offline
Old 03-20-2019, 10:45 AM
  #659
nitro_mt_racer's Avatar
Trader Rating: 225 (100%+)
Considering the fact that it's a rolling change with the same part #, I'd assume they will eventually. Horizon & Amain both show the wrong shock tower if you look up the part #.
nitro_mt_racer is offline
Old 03-21-2019, 10:59 AM
  #660
Maybe I will wait till I know they are included
