Proline Truggy tires >
Like Tree6Likes
  • 1 Post By savage24x
  • 1 Post By token
  • 1 Post By Brian C
  • 2 Post By houston
  • 1 Post By MaricopaAgent
Old 05-15-2018, 07:28 PM
Default Proline Truggy tires
anyone else have trouble with the bead not sitting flush to the rim?. Itís weird when I mount the tire there is a gap from the front edge of the rim and the backside of the bead. Front and back do the same thing.. I take two aka wheel bands front and rear and it kinda makes it better but very sketchy. Anyone else have this issue. My aka cityblocks are perfect lay flat right on the rim.
mattythegreat is offline
Old 05-16-2018, 06:22 AM
savage24x's Avatar
I use Proline Blockades with the Proline VTR wheels. No issues over here.
mattythegreat likes this.
savage24x is offline
Old 05-16-2018, 09:19 AM
Never had an issue when running proline truggy tires.
token is offline
Old 05-16-2018, 10:44 AM
Gonna post pics when I can.
Old 05-16-2018, 05:40 PM
Brian C's Avatar
Trader Rating: 31 (100%+)
I believe that I know what you’re speaking of. I use two 1:10 scale tire bands to hold the tire tight enough to the wheel to be able to glue it. My normal truggy bands aren’t tight enough.
Brian C is offline
Old 05-17-2018, 10:49 AM
Fairly normal for proline truck tires, just do as mentioned and use tire bands to hold them down while you glue.
doesnt affect anything besides the gluing btw.
Gavel is offline
Old 05-17-2018, 12:11 PM
houston's Avatar
Trader Rating: 96 (100%+)
Thumbs up
Originally Posted by mattythegreat View Post
anyone else have trouble with the bead not sitting flush to the rim?. It’s weird when I mount the tire there is a gap from the front edge of the rim and the backside of the bead. Front and back do the same thing.. I take two aka wheel bands front and rear and it kinda makes it better but very sketchy. Anyone else have this issue. My aka cityblocks are perfect lay flat right on the rim.
pro line foams are a bit oversized ..... aka are shaped to the tire profile more , it makes the pro line tires hard to glue i will sometimes use 3 or 4 bands on them ....
TIP: leave the back bead unseated while glueing the front .... this will ensure a better bond on the front side that takes the beating and only leave you with one hard to glue side ....
mattythegreat and token like this.
houston is offline
Old 05-18-2018, 07:51 AM
MaricopaAgent's Avatar
Trader Rating: 28 (100%+)
I use electrical tape..
8T likes this.
MaricopaAgent is offline
Old 05-18-2018, 10:21 AM
houston's Avatar
most hillbilly rednecks do .....
sorry .... had to johnny... hope you are well my man
houston is offline
Old 05-19-2018, 06:23 AM
Well, we know how to figure things out..
Old 05-20-2018, 09:09 AM
Thanks guys great info....
Old 05-22-2018, 06:52 PM
never had a problem here. I used to use tape but don't use anything for the tires. However I do sand the rim and tires with a dremel I also use Loctite super glue to save a few bucks and haven't had a problem yet.
TrespasseR_MN is offline
Old 05-23-2018, 08:23 AM
Anyone ever stay up late and glue a proline tire to an aka wheel Oops. Did t even notice for like a day. I have three proline and one aka. You think that will matter much?
