8ight Evo springs >
8ight Evo springs
Like Tree2Likes
  • 1 Post By cornerspeed
  • 1 Post By token
8ight Evo springs
Old 05-07-2018, 09:37 AM
Default 8ight Evo springs
anyone know if the 16mm springs fit the Truggy as well?
mattythegreat is offline
Old 05-07-2018, 04:41 PM
Kewlbug's Avatar
Trader Rating: 63 (100%+)
They would all be too soft.. Truggy springs are 5.6 - 6lb range.
Kewlbug is offline
Old 05-07-2018, 05:15 PM
cornerspeed's Avatar
I am running the new springs on my truck since DNC. EVO Purple on front and EVO Yellow rear. Just got back from the Silver State race. Ran really good there.
token likes this.
cornerspeed is offline
Old 05-07-2018, 06:35 PM
sure looked like like a bumpy track.... thanks guys.
Old 05-08-2018, 10:20 AM
Im running the same springs on the truck with 5 hole pistons.
mattythegreat likes this.
token is offline
Old 05-10-2018, 03:28 AM
Trader Rating: 21 (100%+)
as mentioned this would soften the truggy up a lot especially with the length in the rear shocks being a bit short! Silver state looked to be really bumpy so if your track is the same it may be the hot set up but for the entire set up on normal track would be getting a rear set of buggy springs for the front on a truggy to start with and see what works. Let us know what u feel after testing. Losi eventually may make a truggy set of evo springs but with the focus shifting to a 5.0 who knows. Like I said stick to evo truggy front shock testing, the rear evos are still way short for a truggy, however you could take it a step further and get yourself some Kyosho springs fro the rear to test as Iíve heard they work with buggy, the truck springs may be key. If u do try to put a buggy rear set of evo speings on the front of a truggy make sure u understand spring rates so it can somewhat be stiff enough because length probably wonít be the same.
Matt Piva is offline
