Which servo for 1/8 throttle? >
Like Tree3Likes
  • 1 Post By sebtarta
  • 1 Post By rcbuggy88
  • 1 Post By token
Old 04-29-2018, 08:00 PM
Default Which servo for 1/8 throttle?
Have a brand new Spektrum 6290 metal case or a Semi used savox 2274sg? Itís going in a losi 8ight T 4.0 nitro. Using the protek 170s for steering.
mattythegreat is offline
Old 04-29-2018, 09:31 PM
The Savox, more torque for breaking. In my opinion.
mattythegreat likes this.
sebtarta is offline
Old 04-29-2018, 10:55 PM
rcbuggy88's Avatar
Spektrum has more speed and still has reasonable torque. Savox does have more though. Personal preference, I would try out both and see which one you like better
rcbuggy88 is offline
Old 04-30-2018, 06:43 AM
mikesd1980's Avatar
Trader Rating: 72 (100%+)
It's not all about the speed of the servo. I don't know the specs to the servos you're using but i would get something something .10-.13. Look at the pros servos and specs. You'll see the speed is not the fastest.
mikesd1980 is offline
Old 04-30-2018, 07:31 AM
Spektrum 6920
Specifications:
Size Category: Standard
  • Type: Digital
  • Application: 1/8 Off-Road
  • Torque:
    • 238 oz-in (17.1kg-cm) @ 6V
    • 292 oz-in (21.0kg-cm) @ 7.4V
    • 331 oz-in (23.8kg-cm) @ 8.4V
  • Speed:
    • 0.09 sec/60 deg @ 6.0V
    • 0.08 sec/60 deg @ 7.4V
    • 0.07 sec/60 deg @ 8.4V
  • Current Draw Idle: 10.2mA @ 6.0V
  • Current Draw Stall: 4900mA @ 6.0V
Savox SB-2274SG
  • Speed:
    • @7.4V: .08 sec/60
    • @6.0V: .105 sec/60
  • Torque:
    • @7.4V: 347.2 oz-in
    • @6.0V: 277.7 oz-in
I would still go with the Savox, more torque and the speed is null for this type of situation.
sebtarta is offline
Old 04-30-2018, 07:36 AM
For the 8.4v on the Spektrum how can you get that for a nitro? Is it possible?
Old 04-30-2018, 04:49 PM
I suggest Spektrum S6390BL
token is offline
Old 04-30-2018, 05:27 PM
He does not have the servo you mentioned. He has the Spektrum 6920 AND/OR Savox SB-2274SG
Why add another servo in the mix is confusing. Also saying something like this without a description as to why makes it even worse.
sebtarta is offline
Old 04-30-2018, 05:29 PM
lipo receiver battery, 7.4v nominal, but usually charges to about 8.4v
blankenj99 is offline
Old 05-02-2018, 04:11 PM
simply miss read. no need to be a dic.
Officespace likes this.
token is offline
Old 05-03-2018, 06:04 AM
sebtarta is offline
Old 05-03-2018, 06:37 AM
tom1974's Avatar
You Can use servo With Speed 0.10 to 0.12
And Power 17 to 30kg
tom1974 is offline
Old 05-03-2018, 07:36 AM
hairymuffin's Avatar
Trader Rating: 102 (100%+)
Wish these servos were no so expensive but the Hitec 9370/9380 has been in my sons car since dnc 2017. Although worth it, too much money for 2 servos
hairymuffin is offline
