Emulsion shocks >
Emulsion shocks
Like Tree3Likes
Emulsion shocks
Old 04-28-2018, 01:09 AM
Default Emulsion shocks
Hi,
i have the feeling that emulsion shocks work perfect
for max a half gal. Then the shocks feel inconsistant. Have other racer this feeling top?
Holymoly
Holymoly is offline
Old 04-28-2018, 03:05 AM
Trader Rating: 89 (100%+)
Are you bleeding them routinely? I check mine after a few runs and before the main. If they get to much air inside they will feel inconsistent.
b121774 is offline
Old 04-28-2018, 06:04 AM
Thought they work with oil air mix?
Holymoly
Holymoly is offline
Old 04-28-2018, 06:17 AM
They do but it is a balance between the two. Too much or too little can cause either a dead spot or too much rebound. Air slowly Works its way in in a little oil slowly Works its way out. When you take the shock Off remove the spring and pump the shock about 20 times or so. If the Piston pops immediately out then you have too much Rebound in too much air. if you have a dead spot still after pumping shock up then you have to little oil.
b121774 is offline
Old 04-28-2018, 11:10 AM
I was just thinking about switching to emulsion with the TLR shocks. Do they really offer any advantage over bladder or its just more consistent?
Evoking1230 is offline
Old 04-28-2018, 09:08 PM
In my experience, emulsion handles bumps WAY better. And any flat landings, it takes out alot of the pop you might get.
Evoking1230 and token like this.
Gavel is offline
Old 04-29-2018, 07:54 AM
thanks.
Liking what im reading so far. :-)
Old 04-30-2018, 08:55 AM
Do you think it has to do with rebound? I have a hard time getting zero rebound on a bladder.
snowninja is offline
Old 04-30-2018, 01:09 PM
i agree with this... Was thinking of switching too.
mattythegreat is offline
Old 04-30-2018, 04:29 PM
Make sure there are no air bubbles in the oil prior to installing the cap. You will need to bleed the shock a few times. I bleed mine when I build them, then before qualifiers and again before the main.
token is offline
Old 04-30-2018, 06:34 PM
you talking bladder or emulsion?
Old 04-30-2018, 07:23 PM
fyrstormer's Avatar
The cool thing about emulsion shocks is the amount of shock actuation influences the amount of air churned into the oil, and thus affects the viscosity of the oil. So if you're driving on rough terrain they will soften-up, and if you're driving on smooth terrain they will firm-up.
Unfortunately, I've never actually gotten this to work very well in practice. The base viscosity of the oil affects how easily air is churned into the oil on rough terrain, and how easily air escapes from the oil on smooth terrain, so you have to pick your oil viscosity based on how much "lag" you want between the terrain changing and the oil viscosity changing. Then you have to change your shock pistons (or modify them, if you don't have enough pre-made pistons to choose from) to actually get the amount of damping you want with the viscosity of oil you selected.
When it comes down to it, since track layouts generally don't change in the middle of a race day, you don't really need the oil viscosity to self-adjust based on terrain changes, because there aren't any terrain changes for you to worry about. It's a lot easier to use bladders, take your time to get every last little bubble out of the shocks during assembly, and get perfectly consistent shock performance in the narrow range of conditions present on any given track.
fyrstormer is offline
Old 04-30-2018, 07:25 PM
fyrstormer's Avatar
Depends on the effect you're going for. Air bubbles don't just dynamically thin-out the oil, they also transform the oil into an elastic fluid, so it can stretch and compress instead of being forced to pass through the holes in the piston. This gives much softer damping on sharp impacts. That may be what you want, but I've never encountered a situation where I wanted one of my RCs to bottom-out more often.
Old 05-01-2018, 03:06 PM
Emulsion
token is offline
Old 05-02-2018, 08:17 AM
Hi think emulsion shocks have 2 advantages!
1. easier to create zero rebound
2. no double bouncing after landings
But thats it.
Holymoly
Holymoly is offline
