-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   Losi ten t nitro questions (https://www.rctech.net/forum/nitro-off-road/1016124-losi-ten-t-nitro-questions.html)
darryl1980 04-18-2018 03:01 AM
Would a metal MIP 39T or 41T sour gear be a smart upgrade to do?
darryl1980 04-19-2018 07:53 PM
Is there a certain process to connect spektrum dx3s radio to R.O.S.S. remote onboard starting system any links or helpful information would be greatly appreciated.
Evoking1230 04-20-2018 08:51 AM
Nitro and Plastic Spur gears usually don't go well together. Sometimes yes, but mainly no.
It's one of those do it and forget about it upgrades, for peace of mind :-)
darryl1980 04-20-2018 10:44 AM
Would a MIP metal spur gear be the way to go and should I go with the same tooth count too?
darryl1980 04-22-2018 07:07 AM
Can scte front bumper and rear bumper with mudflaps be put on losi ten t nitro I am just curious.
RCTecher12 04-22-2018 07:59 AM
If properly setup, plastic spurs work just fine. I’ve been using them for 20 years. I tried a Robinson racing steel spur on a Nitro Rusty one time; I wore the clutchbell out in 3 tanks. Hardened steel spur requires a hardened steel clutchbell. In some cases, fully hardened clutchbells may not be available for your application. You have to do your homework - not all steel clutchbells and spur gears are created alike.
And FWIW - more spur teeth and/or less clutchbell teeth = less top speed and more acceleration. Less spur teeth and more clutchbell teeth = less acceleration and more top speed.
darryl1980 04-22-2018 04:29 PM
Is there a lipo receiver battery pack that I can get without using the losi ross box I am not using the ross starting system on mine any links would help me out alot thank you and have a good day guys.
