Hyper 7.5 RTR - Breaking Weak - Question >
Like Tree1Likes
  • 1 Post By NitroB810
Old 12-24-2017, 11:33 AM
Default Hyper 7.5 RTR - Brakes Weak - Question Please help
1
NitroB810 is offline
Old 12-24-2017, 12:21 PM
mxking1712's Avatar
there should be a small collar that would sit against the spring on the brake linkage, you should be able to loosen this off and slide it a few mm closer to the spring. this will improve your brakes.
another option is to get rid of the spring all together and install a piece of fuel tubing that is the same size as the spring. the fuel tubing will have less "give" than the spring and will in return give your stronger braking power.
make sure after you move the collar or use the fuel tubing that when your throttle is in its neutral position, your breaks aren't binding.
mxking1712 is offline
Old 12-24-2017, 01:53 PM
The collar on the brakes looks fine + dont think the brake is a problem as its a new machine.
Can this be fixed on the RC transmitter?
Like the breaks work absolutely fine, when I switch the throttle to reverse (R) on the transmitter
Old 12-24-2017, 04:08 PM
Mxking1712
Actually you were correct about the two collars!
Thank you very simple fix.
I'll post a pic for future people struggling asap.
CBren32 likes this.
