Like Tree244Likes
Mugen MBX8
    Hide Wikipost
Old 03-15-2019, 09:38 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX8
Last edit by: E1 Diablo
E2021 - MBX8 1/8 Nitro Buggy Kit
Chassis:
The MBX8 chassis features a new design that improves traction and stability in bumpy conditions and on the exit of corners. The steering post are also keyed into the MBX8 chassis for easier maintenance.
Differential & drive train:
High Traction Differentials are included in the MBX8. The Mugen Seiki HTD provides increased acceleration, longer runtime, and more consistent handling. The HTD's also increase stability, traction, and improve handling in bumpy conditions. The HTD has a new larger volume diff cup to increase consistency during long main events. This makes it easier to time rhythm sections, better in bumpy and low grip conditions, helps to increase traction, and increases fuel mileage.
The new gearbox makes allows you to remove and service the differentials without detaching the suspension arm mounts. Easy access to the front and rear differential.
New straight cut 13T bevel gear & 44T conical gear. The new straight cut bevel and conical gears increase acceleration, runtime, and efficiency. A free and efficient drive train will also increase speeds while cornering.
Light weight one-piece wing mount:
The new lightweight one-piece wing mount lower the center of gravity. The position of the wing and wing mount is optimized to improve the performance of vehicle. The height of the wing mount is adjustable. This allows you to control the down force on the rear of the vehicle by simply raising or lowering the mount on the shock tower.
Light weight high down-force wing:
The new IFMAR legal wing is lightweight and provides amazing down force and cornering. The underside of the wing uses a new design to reduced weight and creates additional down-force.
Suspension:
New suspension mounts. The FF/FR/RF/RR are new for the MBX8.
The front and rear lower arms use a new impact resistant material for increased durability. The new arms are box-shaped and include arm stiffeners to reduce flex and increase durability. Adjusting the hardness of the lower suspension arms is now possible. This allows you to fine tune the steering and traction from track to track. CFRP plates will be released as an option part.
Center differential mount & plate:
The center differential mounts use a stiffer material and has a new top plate to reduce chassis flex and increases clutch bell, spur gear, and clutch bearing life. The reduced chassis flex also provides more consistent handling in all conditions. The top plate design also makes it easier to adjust the brakes and easier maintenance.
Enclosed Battery box and updated carbon fiber radio plate:
The MBX8 still uses a flat 2S Lipo or Life battery, but the receiver battery is now enclosed in a molded battery box. The battery box allows for quick and easy access to the battery. The molded box also helps protect the battery from hard impacts. The battery box is mounted to an updated carbon fiber radio plate.
Other new parts and upgrades:
Body, Clamping Servo Saver Nut, F/R Shock Towers, Front bumper, Front center and rear center universal joint.
Mugen Seiki MBX8 Manual
Print Wikipost
Old 05-01-2019, 12:54 PM
  #916
tom1974's Avatar
has anyone tried the new mbx8 wc?
what differences did you notice with respect to the std?
thanks
tom1974 is offline
Old 05-13-2019, 03:03 PM
  #917
Anyone know what the little pan head screws are for with the aluminum hubs?
Cardiak is offline
Old 05-15-2019, 11:29 PM
  #918
Absolute has the mbx8 for $500 shipped.
Niz55 is offline
Old 05-15-2019, 11:56 PM
  #919
Still normal price for me.
Chris Reilly likes this.
Cardiak is offline
Old 05-18-2019, 04:05 PM
  #920
Regular price here as well
Chris Reilly is offline
Old 05-21-2019, 01:25 PM
  #921
is that with a coupon code? I see $569.00
shark2288 is offline
Old 05-21-2019, 01:31 PM
  #922
hyperfuxx's Avatar
Trader Rating: 28 (97%+)
Screw for the little oil port
hyperfuxx is offline
Old 05-21-2019, 02:15 PM
  #923
Really? I never put oil in there and the bearing seems fine and I have about 4 gallons on them. I have a 7TR that I bash.
Cardiak is offline
Old 05-21-2019, 02:27 PM
  #924
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 85 (100%+)
It just a old design that has managed to survive the last few cars iterations, 5, 6,7, and 8.
No oil needed, just maintain your bearings, and anyway thats like asking for trouble anyway, like giving all the dust another (oil) means to easily destroy your bearings to begin with.
1/8 IC Fan is offline
Old 05-21-2019, 09:32 PM
  #925
Yes coupon code is may55
$514 with free shipping .
I actually was going to buy it but got better deal on a rc8b3.1
Both cars are very very similar and both cars are excellent quality. Mugen is 5 min away from me and some nice people work there including Adam. I buy my fuel from Mugen directly.
I was looking at the mp10 becuase I had the mp9 and I got tired of breaking front arms constantly. Some folks at track were complaining about breaking arms on the new mp10 also so I backed out.
Niz55 is offline
Old 05-21-2019, 09:41 PM
  #926
Where are you located? Cali?
Cardiak is offline
Old 05-21-2019, 11:07 PM
  #927
Yes. Southern CA.
Niz55 is offline
