Like Tree243Likes
Mugen MBX8
    Hide Wikipost
Old 03-15-2019, 09:38 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX8
Last edit by: E1 Diablo
E2021 - MBX8 1/8 Nitro Buggy Kit
Chassis:
The MBX8 chassis features a new design that improves traction and stability in bumpy conditions and on the exit of corners. The steering post are also keyed into the MBX8 chassis for easier maintenance.
Differential & drive train:
High Traction Differentials are included in the MBX8. The Mugen Seiki HTD provides increased acceleration, longer runtime, and more consistent handling. The HTD's also increase stability, traction, and improve handling in bumpy conditions. The HTD has a new larger volume diff cup to increase consistency during long main events. This makes it easier to time rhythm sections, better in bumpy and low grip conditions, helps to increase traction, and increases fuel mileage.
The new gearbox makes allows you to remove and service the differentials without detaching the suspension arm mounts. Easy access to the front and rear differential.
New straight cut 13T bevel gear & 44T conical gear. The new straight cut bevel and conical gears increase acceleration, runtime, and efficiency. A free and efficient drive train will also increase speeds while cornering.
Light weight one-piece wing mount:
The new lightweight one-piece wing mount lower the center of gravity. The position of the wing and wing mount is optimized to improve the performance of vehicle. The height of the wing mount is adjustable. This allows you to control the down force on the rear of the vehicle by simply raising or lowering the mount on the shock tower.
Light weight high down-force wing:
The new IFMAR legal wing is lightweight and provides amazing down force and cornering. The underside of the wing uses a new design to reduced weight and creates additional down-force.
Suspension:
New suspension mounts. The FF/FR/RF/RR are new for the MBX8.
The front and rear lower arms use a new impact resistant material for increased durability. The new arms are box-shaped and include arm stiffeners to reduce flex and increase durability. Adjusting the hardness of the lower suspension arms is now possible. This allows you to fine tune the steering and traction from track to track. CFRP plates will be released as an option part.
Center differential mount & plate:
The center differential mounts use a stiffer material and has a new top plate to reduce chassis flex and increases clutch bell, spur gear, and clutch bearing life. The reduced chassis flex also provides more consistent handling in all conditions. The top plate design also makes it easier to adjust the brakes and easier maintenance.
Enclosed Battery box and updated carbon fiber radio plate:
The MBX8 still uses a flat 2S Lipo or Life battery, but the receiver battery is now enclosed in a molded battery box. The battery box allows for quick and easy access to the battery. The molded box also helps protect the battery from hard impacts. The battery box is mounted to an updated carbon fiber radio plate.
Other new parts and upgrades:
Body, Clamping Servo Saver Nut, F/R Shock Towers, Front bumper, Front center and rear center universal joint.
Mugen Seiki MBX8 Manual
Print Wikipost
Old 03-16-2019, 02:41 PM
  #886
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 85 (100%+)
Originally Posted by Cardiak View Post
Anyone know if Amain has any 10% or 15% coupons going right now? And why isn't there a subforum for them anymore?
This one?
Amain Coupon Code
1/8 IC Fan is offline
Old 03-16-2019, 02:53 PM
  #887
Originally Posted by 1/8 IC Fan View Post
Yep. That's weird. I'm not able to access that part of the forum anymore.
Cardiak is offline
Old 03-17-2019, 04:36 PM
  #888
ASA
ASA's Avatar
When your on the Amain site, just type Coupon Codes into their search and it comes up with the current ones.....easy as
ASA is offline
Old 03-17-2019, 05:26 PM
  #889
Yeah but it won't show the 10% or 15% promo coupons.
Cardiak is offline
Old 03-22-2019, 04:10 AM
  #890
Super Moderator
1/8 IC Fan's Avatar
From REDRC
Worlds Edition MBX8:
Mugen Seiki have released the MBX8 Worlds Edition Nitro Buggy kit. It includes many of option parts used by Mugen Seiki drivers at the 2018 IFMAR World Championship where the Japanese brand had four MBX8ís in the 60 Minute final with Ryan Maifield finishing on the podium. The MBX8 Worlds Edition includes inline front uprights that have smoother steering compared to the stock trailing front uprights and work great in high traction conditions. The -3mm front upright arms are also included and improve the initial steering response and make the vehicle more stable through the middle and exit of the corner. Different transmission parts are also supplied such as the 46 tooth HTD spur gear, 12T bevel gear, 42T conical gear, front and rear-centre dogbones and finally the +15mm wing mount.
Old 03-22-2019, 04:37 AM
  #891
Maxxingout's Avatar
Trader Rating: 17 (100%+)
So am I understanding this correctly? The Worlds Edition parts are more suited for a higher bite type track?
Maxxingout is offline
Old 03-22-2019, 04:42 AM
  #892
hyperfuxx's Avatar
Trader Rating: 27 (97%+)
Does this come with the Associated wing? Seems kinda goofy considering most of us have these parts already on our cars.
hyperfuxx is offline
Old 03-22-2019, 07:05 AM
  #893
cHAmpa's Avatar
Trader Rating: 26 (100%+)
Obviously, this isn't for those who already have the parts on their car. It would be for those that are looking to pick up a new kit... they now don't have to pick up the kit AND all the hop ups.
Mugen wings, HB wings, Associated wings... people will always use what feels good to them.
mtbkym01 likes this.
cHAmpa is offline
Old 03-22-2019, 07:16 AM
  #894
slackinoff's Avatar
It's actually kind of impressive that there is that little difference between a car on the podium at the worlds vs. the one in the box. Mugen has a SOLID platform.
RandyJones likes this.
slackinoff is offline
Old 03-24-2019, 06:50 PM
  #895
Default Parts
Hello everyone I have the Mbx8 and the mbx8t just Finishing up on my builds and getting ready to go racing want to know what people have gotten for spare parts what are the parts that the cars have been breaking and or waring out what extras do people have for their cars just want to be prepared! Thanks!
racelukatic is offline
Old 03-24-2019, 10:39 PM
  #896
The car is unbelievably durable, so most of these items are typical maintenance related regardless of the platform:
Shock internals
Diff o-rings and gaskets
Fuel tubing
Get an extra bearing kit - easy to swap out wasted bearings
Plugs
Air filters
Hinge pin block bushings
Clutch shoes/springs
Pipe and manifold gaskets
Pillow ball bushings
Get an extra set of screws just in case you strip the heads of any kit screws
I usually keep an extra set of front shock shafts and A-arms just in case - if the arm goes then the shock shaft will go too
racelukatic likes this.
Ratdog is offline
Old 03-26-2019, 05:16 PM
  #897
rcmania74's Avatar
Trader Rating: 55 (98%+)
Anyone looking for a new upgraded 8 roller fairly cheap.....i know a guy
rcmania74 is offline
Old 03-30-2019, 08:35 PM
  #898
Hindle Racing's Avatar
how much?
Hindle Racing is offline
Old 04-09-2019, 05:27 PM
  #899
What diff setup and shock/piston/oil setup did anyone use at pnb this past weekend. Think I was off on the setup struggled with buggy all weekend... just wanted to Compare with what others may have ran. Thanks
Hotspur is offline
Old 04-14-2019, 08:27 AM
  #900
Default Amain codes
Does any one know of some amain codes, thanks
PoorBoy534 is offline
