Like Tree235Likes
Mugen MBX8
    Hide Wikipost
Old 03-15-2019, 09:38 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX8
Last edit by: E1 Diablo
E2021 - MBX8 1/8 Nitro Buggy Kit
Chassis:
The MBX8 chassis features a new design that improves traction and stability in bumpy conditions and on the exit of corners. The steering post are also keyed into the MBX8 chassis for easier maintenance.
Differential & drive train:
High Traction Differentials are included in the MBX8. The Mugen Seiki HTD provides increased acceleration, longer runtime, and more consistent handling. The HTD's also increase stability, traction, and improve handling in bumpy conditions. The HTD has a new larger volume diff cup to increase consistency during long main events. This makes it easier to time rhythm sections, better in bumpy and low grip conditions, helps to increase traction, and increases fuel mileage.
The new gearbox makes allows you to remove and service the differentials without detaching the suspension arm mounts. Easy access to the front and rear differential.
New straight cut 13T bevel gear & 44T conical gear. The new straight cut bevel and conical gears increase acceleration, runtime, and efficiency. A free and efficient drive train will also increase speeds while cornering.
Light weight one-piece wing mount:
The new lightweight one-piece wing mount lower the center of gravity. The position of the wing and wing mount is optimized to improve the performance of vehicle. The height of the wing mount is adjustable. This allows you to control the down force on the rear of the vehicle by simply raising or lowering the mount on the shock tower.
Light weight high down-force wing:
The new IFMAR legal wing is lightweight and provides amazing down force and cornering. The underside of the wing uses a new design to reduced weight and creates additional down-force.
Suspension:
New suspension mounts. The FF/FR/RF/RR are new for the MBX8.
The front and rear lower arms use a new impact resistant material for increased durability. The new arms are box-shaped and include arm stiffeners to reduce flex and increase durability. Adjusting the hardness of the lower suspension arms is now possible. This allows you to fine tune the steering and traction from track to track. CFRP plates will be released as an option part.
Center differential mount & plate:
The center differential mounts use a stiffer material and has a new top plate to reduce chassis flex and increases clutch bell, spur gear, and clutch bearing life. The reduced chassis flex also provides more consistent handling in all conditions. The top plate design also makes it easier to adjust the brakes and easier maintenance.
Enclosed Battery box and updated carbon fiber radio plate:
The MBX8 still uses a flat 2S Lipo or Life battery, but the receiver battery is now enclosed in a molded battery box. The battery box allows for quick and easy access to the battery. The molded box also helps protect the battery from hard impacts. The battery box is mounted to an updated carbon fiber radio plate.
Other new parts and upgrades:
Body, Clamping Servo Saver Nut, F/R Shock Towers, Front bumper, Front center and rear center universal joint.
Mugen Seiki MBX8 Manual
Print Wikipost
Old 03-03-2019, 07:20 PM
  #871
Super Moderator
1/8 IC Fan's Avatar
Trader Rating: 79 (100%+)
Originally Posted by Hotspur View Post
What clutch is everyone running? I’m currently using Mugen 4 shoe, buti have been breaking a clutch springs every race day... Thoughts on M2C 4 shoe clutch?
I had went back to the 3 shoe clutch for now, that is just based on the amount of spares I had for the MBX7 cars. Have you tried other compounds of shoes, is it perhaps due to overheating ? Give the Protek ones a try. https://www.amainhobbies.com/protek-...k-7511/p524206 They have two different sets, one is softer and one harder just as an FYI
1/8 IC Fan is offline
Old 03-03-2019, 07:44 PM
  #872
What clutch is everyone running? Iím currently using Mugen 4 shoe, buti have been breaking a clutch springs every race day... Thoughts on M2C 4 shoe clutch?
Buku
Cardiak is offline
Old 03-03-2019, 08:22 PM
  #873
Trader Rating: 34 (97%+)
Anyone try running 6/10/4 or 6/8/4?
alfanna909 is offline
Old 03-05-2019, 03:42 PM
  #874
WTDblNut's Avatar
Trader Rating: 16 (100%+)
On Drake's buggy it looks like an elbow coming out of the fuel tank for the fuel supply line. Anyone know where to get one of these or better yet a part number?
WTDblNut is offline
Old 03-05-2019, 04:31 PM
  #875
criss2115's Avatar
Originally Posted by 1/8 IC Fan View Post
Mugens wheel nuts PN- E0219 are actually aluminum, since the MBX-5
My mistake. Then they are hard anodized. They are hard on hubs.
criss2115 is offline
Old 03-05-2019, 10:39 PM
  #876
Trader Rating: 61 (100%+)
LOSA9164
mr240 is offline
Old 03-06-2019, 06:50 AM
  #877
am
It is a Losi part from the erly 8ight cars. I used them myself on the MBX8. I do not have a part number. I think you have to buy the tank.
am is offline
Old 03-06-2019, 10:31 AM
  #878
tom1974's Avatar
https://www.amainhobbies.com/losi-efra-fuel-tank-kit-8b-8t-2.0-losa9164/p141082
tom1974 is offline
Old 03-06-2019, 10:36 AM
  #879
tom1974's Avatar
Have you link or photos Drake's car?
tom1974 is offline
Old 03-06-2019, 02:37 PM
  #880
WTDblNut's Avatar
Thanks for the replies. Looks like that part number is discontinued everywhere and would have to buy the tank now. Here is the pic I was looking at......
WTDblNut is offline
Old 03-15-2019, 12:43 PM
  #881
am
Default Mugen 4shoe clutch - bad springs
Hi,
Ran Mugen clutch and had a spring breake. I then sold the car to back to Kyosho. Guy buing my spare stuff have a clutchspring go bad evry oputing. We have seen alot of this on the 4 shoe Mugen clutch.
Does anyone now if Losi or M2C or any other springs will fit?
Thanks!
am is offline
Old 03-15-2019, 12:47 PM
  #882
theres a reason the mugen 4 shoe is unused. use the whole AE clutch, werks or reds etc
iplaygames is offline
Old 03-16-2019, 02:38 PM
  #883
Anyone know if Amain has any 10% or 15% coupons going right now? And why isn't there a subforum for them anymore?
Cardiak is offline
Old 03-16-2019, 02:41 PM
  #884
Super Moderator
1/8 IC Fan's Avatar
This one?
Amain Coupon Code
Old 03-16-2019, 02:53 PM
  #885
Yep. That's weird. I'm not able to access that part of the forum anymore.
Cardiak is offline
