Mugen MBX8
#856
hi, has anyone tried the fastrace bladders and caps?
#858
Mbx8 ecco
Where can I find a pill chart.
#860
R/C Tech Elite Member
Trader Rating: 123 (100%+)
#861
What's everyone using for clutch bells with aftermarket clutches? still the mugen one? and what clutch is everyone using?
#862
Buku clutch with stock bell.
#865
Wheel hub/nut problems
I am having a problem with the wheel nut getting stuck on the wheel hub and having to cut them off and having to replace the hub. They are essentially becoming cross threaded but I put them on with an AKA T handle wrench and they thread on easily...not with a small impact like I see a lot of guys doing. I have had two already do this and one of the guys I race with has had it happen to him as well...any explanations??
#866
#867
Yes and yes
#868
is the tread full of dirt before trying to take them off?
#869
Try running capped wheel nuts I had this issue once. I think my buggy got caught up on one of the big nails that hold down the track pipes and it dented the threads. Ever since I switched to the capped ones have had a issue since plus keeps dirt put of the thread
#870
Stock nuts are steel. They gall the alum threads or if overtightened actually distort the thread pitch. Go to the flashpoint alum caps and your problems will be solved.
