Like Tree244Likes
Mugen MBX8
    Hide Wikipost
Old 03-15-2019, 09:38 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX8
Last edit by: E1 Diablo
E2021 - MBX8 1/8 Nitro Buggy Kit
Chassis:
The MBX8 chassis features a new design that improves traction and stability in bumpy conditions and on the exit of corners. The steering post are also keyed into the MBX8 chassis for easier maintenance.
Differential & drive train:
High Traction Differentials are included in the MBX8. The Mugen Seiki HTD provides increased acceleration, longer runtime, and more consistent handling. The HTD's also increase stability, traction, and improve handling in bumpy conditions. The HTD has a new larger volume diff cup to increase consistency during long main events. This makes it easier to time rhythm sections, better in bumpy and low grip conditions, helps to increase traction, and increases fuel mileage.
The new gearbox makes allows you to remove and service the differentials without detaching the suspension arm mounts. Easy access to the front and rear differential.
New straight cut 13T bevel gear & 44T conical gear. The new straight cut bevel and conical gears increase acceleration, runtime, and efficiency. A free and efficient drive train will also increase speeds while cornering.
Light weight one-piece wing mount:
The new lightweight one-piece wing mount lower the center of gravity. The position of the wing and wing mount is optimized to improve the performance of vehicle. The height of the wing mount is adjustable. This allows you to control the down force on the rear of the vehicle by simply raising or lowering the mount on the shock tower.
Light weight high down-force wing:
The new IFMAR legal wing is lightweight and provides amazing down force and cornering. The underside of the wing uses a new design to reduced weight and creates additional down-force.
Suspension:
New suspension mounts. The FF/FR/RF/RR are new for the MBX8.
The front and rear lower arms use a new impact resistant material for increased durability. The new arms are box-shaped and include arm stiffeners to reduce flex and increase durability. Adjusting the hardness of the lower suspension arms is now possible. This allows you to fine tune the steering and traction from track to track. CFRP plates will be released as an option part.
Center differential mount & plate:
The center differential mounts use a stiffer material and has a new top plate to reduce chassis flex and increases clutch bell, spur gear, and clutch bearing life. The reduced chassis flex also provides more consistent handling in all conditions. The top plate design also makes it easier to adjust the brakes and easier maintenance.
Enclosed Battery box and updated carbon fiber radio plate:
The MBX8 still uses a flat 2S Lipo or Life battery, but the receiver battery is now enclosed in a molded battery box. The battery box allows for quick and easy access to the battery. The molded box also helps protect the battery from hard impacts. The battery box is mounted to an updated carbon fiber radio plate.
Other new parts and upgrades:
Body, Clamping Servo Saver Nut, F/R Shock Towers, Front bumper, Front center and rear center universal joint.
Mugen Seiki MBX8 Manual
Print Wikipost
Old 11-26-2018, 03:57 PM
  #826
fastchvy's Avatar
Trader Rating: 15 (100%+)
fastchvy is offline
  #827
fastchvy's Avatar
His contact info^^^^^^^^^
fastchvy is offline
Old 11-27-2018, 01:31 AM
  #828
tom1974's Avatar
[QUOTE = Paultje040; 15342718] su ebay.
Penso che l'uno sia fantastico. [/ QUOTE]
i use t works Now*
Paultje040 likes this.
tom1974 is online now
Old 11-28-2018, 08:00 PM
  #829
Do hdd type differentials really make a difference or is it just marketing? Is anyone who has ever used hb, do you know if its differentials are smaller than those of mbx8?
Paulo Braz is offline
Old 11-28-2018, 11:20 PM
  #830
tom1974's Avatar
Yes man with ht the car in more aggressive and more traction
Old 11-29-2018, 04:34 PM
  #831
What springs for the brake pads? the little ones that go between calipers to keep them apart
MonsterJuice is offline
Old 11-29-2018, 06:26 PM
  #832
fastchvy's Avatar
I used losi springs
8T likes this.
fastchvy is offline
Old 11-29-2018, 10:44 PM
  #833
tom1974's Avatar
Associated or xray
Old 12-02-2018, 05:33 PM
  #834
E1 Diablo's Avatar
I sometimes use two shock o-rings per screw, but it's really not that big a deal. You can also cut up the spring out of a pen and save some money vs. buying "RC" springs..
E1 Diablo is offline
Old 12-03-2018, 06:26 AM
  #835
GREGORY!'s Avatar
what is the standard height in blank rims?
thanks.
criss2115 likes this.
GREGORY! is offline
Old 12-09-2018, 09:37 AM
  #836
tom1974's Avatar
Which body use Ryan maifield?
Old 12-09-2018, 10:16 AM
  #837
Trader Rating: 20 (100%+)
He uses JConcepts bodies. The particular one depends on the track and what they are trying to promote at the time.
MX304 is offline
Old 12-09-2018, 10:58 PM
  #838
tom1974's Avatar
what is the name of the body?
Old 12-11-2018, 04:43 AM
  #839
Could be Jconcepts S15 (worlds prototype), S3, or Silencer
Buckland is offline
Old 12-12-2018, 04:48 AM
  #840
hyperfuxx's Avatar
Trader Rating: 28 (97%+)
Does anybody know if the AE sway bars fit the mugen?
hyperfuxx is offline
