Like Tree244Likes
Mugen MBX8
    Hide Wikipost
Old 03-15-2019, 09:38 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX8
Last edit by: E1 Diablo
E2021 - MBX8 1/8 Nitro Buggy Kit
Chassis:
The MBX8 chassis features a new design that improves traction and stability in bumpy conditions and on the exit of corners. The steering post are also keyed into the MBX8 chassis for easier maintenance.
Differential & drive train:
High Traction Differentials are included in the MBX8. The Mugen Seiki HTD provides increased acceleration, longer runtime, and more consistent handling. The HTD's also increase stability, traction, and improve handling in bumpy conditions. The HTD has a new larger volume diff cup to increase consistency during long main events. This makes it easier to time rhythm sections, better in bumpy and low grip conditions, helps to increase traction, and increases fuel mileage.
The new gearbox makes allows you to remove and service the differentials without detaching the suspension arm mounts. Easy access to the front and rear differential.
New straight cut 13T bevel gear & 44T conical gear. The new straight cut bevel and conical gears increase acceleration, runtime, and efficiency. A free and efficient drive train will also increase speeds while cornering.
Light weight one-piece wing mount:
The new lightweight one-piece wing mount lower the center of gravity. The position of the wing and wing mount is optimized to improve the performance of vehicle. The height of the wing mount is adjustable. This allows you to control the down force on the rear of the vehicle by simply raising or lowering the mount on the shock tower.
Light weight high down-force wing:
The new IFMAR legal wing is lightweight and provides amazing down force and cornering. The underside of the wing uses a new design to reduced weight and creates additional down-force.
Suspension:
New suspension mounts. The FF/FR/RF/RR are new for the MBX8.
The front and rear lower arms use a new impact resistant material for increased durability. The new arms are box-shaped and include arm stiffeners to reduce flex and increase durability. Adjusting the hardness of the lower suspension arms is now possible. This allows you to fine tune the steering and traction from track to track. CFRP plates will be released as an option part.
Center differential mount & plate:
The center differential mounts use a stiffer material and has a new top plate to reduce chassis flex and increases clutch bell, spur gear, and clutch bearing life. The reduced chassis flex also provides more consistent handling in all conditions. The top plate design also makes it easier to adjust the brakes and easier maintenance.
Enclosed Battery box and updated carbon fiber radio plate:
The MBX8 still uses a flat 2S Lipo or Life battery, but the receiver battery is now enclosed in a molded battery box. The battery box allows for quick and easy access to the battery. The molded box also helps protect the battery from hard impacts. The battery box is mounted to an updated carbon fiber radio plate.
Other new parts and upgrades:
Body, Clamping Servo Saver Nut, F/R Shock Towers, Front bumper, Front center and rear center universal joint.
Mugen Seiki MBX8 Manual
Print Wikipost
Old 07-19-2018, 05:47 AM
  #646
KINGZJ's Avatar
Why are people using other than Mugen parts on this car? I have at least 4 gallons through mine and have yet to find the need to use any other manufactuers parts. O wait I supose I do have kyosho fuel line on my car and a jconcepts body.
KINGZJ is offline
Old 07-19-2018, 06:22 AM
  #647
Because I have a Buku clutch and the Mugen bell doesn't fit well with it. And I want the 15T cb. Mugen doesn't have one.
Cardiak is offline
Old 07-19-2018, 07:07 AM
  #648
What lipo are we using for our mbx8? Want the flashpoint but it’s out of stxock at amain...
mattythegreat is offline
Old 07-19-2018, 09:49 AM
  #649
Maxxingout's Avatar
Trader Rating: 17 (100%+)
https://www.amainhobbies.com/protek-...tk-5196/p15789
This is the one I'm using. Fits nice with plenty of wire room.
mattythegreat likes this.
Maxxingout is offline
Old 07-19-2018, 10:30 AM
  #650
KINGZJ's Avatar
I really wasnt refering to your post. Im not a fan of the buku but I know many who like it. I do question the 15t clutch bell thats huge. Must be a large track or your engine is a stump puller.
KINGZJ is offline
Old 07-19-2018, 12:23 PM
  #651
tom1974's Avatar
noooo....it's more expensive
tom1974 is offline
Old 07-19-2018, 12:30 PM
  #652
tom1974's Avatar
https://www.amainhobbies.com/mugen-seiki-15t-clutch-bell-muge0709/p29906
tom1974 is offline
Old 07-19-2018, 01:40 PM
  #653
I have a 7tr with a 28-8 for bashing. I posted in this thread because it's far more active.
Cardiak is offline
Old 07-19-2018, 07:04 PM
  #654
Can someone give me the dimensions of the battery box.. Trying to order a lipo on the cheap side and need to k ow where I need to be. My buggy won’t get here till next week.
Old 07-19-2018, 07:10 PM
  #655
I believe the Flash Point pack will restock at Amain on 8/2 if you can wait a couple of weeks.
Cardiak is offline
Old 07-20-2018, 04:32 AM
  #656
Maxxingout's Avatar
They go for the same price on a-main
https://www.amainhobbies.com/flash-p...pr2001/p496158
Old 07-20-2018, 05:24 AM
  #657
tom1974's Avatar
You Can Buy hobby King Life or lipo
tom1974 is offline
Old 07-20-2018, 11:14 AM
  #658
tom1974's Avatar
jmoneym and debocurl5.0 like this.
tom1974 is offline
Old 07-20-2018, 11:17 AM
  #659
tom1974's Avatar
flap jack and debocurl5.0 like this.
tom1974 is offline
Old 07-22-2018, 10:06 AM
  #660
R4ge's Avatar
Hi to all!
New here and new owner of mbx8!
R4ge is offline
