Mugen MBX8
#34
yes I like to hit shit but some time I try not to but get push in too it
#36
We talking about the truggy
#38
I think perhaps the people that were asking 2 years ago about a successor to the MBX7R had all moved to new platforms instead of buying an MBX7R, lol.
... So I will Start, I hope it keeps the MBX7R Shocks... Nothing wrong there, and no I don't need a split diff mount.
#42
Alright guys, I have permission to talk about the MBX8 now that Xray has shown the '18 XB8.
The changes are small, some of the older mugen guys will remember that there was once a version like this. The changes are small and will deceive you into thinking it's a 7 but rest assured it's evolutionary rather than revolutionary.
First and foremost are the LW aluminium drivetrain parts, like the MBX6R and yes back to CVDs. 4 shoe clutch.
Suspension wise the shock towers are lower and the shocks are shorter as the travel is more efficiently used. Bleeder caps are standard. Front lower arms are like the Truggy front arms, with hinge pin bracing. The new base setup as been developed using 1:1 top tier racing wisdom and parts were changed and bettered to have the least amount of compromises setup wise, added the much awaited up travel limiters AKA bump stops. The out of the box setup is even better and the amount of option parts you have to acquire is cut down immensely.
Steering geometry is better, bump steer is kept to a minimum and now it actually works to our benefit.
Radio tray is new, steering servo now transversely mounted and the electronics sit close to the steering servo.
Centre diff support is new, now the brake calipers are side mounted so there isn't a need for a reinforcement.
The chassis is new, with the component placement being more tidy and efficient there was a great effort to centralize mass. The engine and centre diff are moved right and back, the fuel tank slightly outwards and the electronics to the left. Front and rear overhang are kept to the minimum possible by going long wheelbase. To be included is a 30gr ballast because in certain engine/electronics/tires combo the buggy can be underweight!
The new body has smoother lines and transitions. Aerodynamics are better, mainly flow attachment and the entire body helps the car cut through the air effortlessly while helping cool what's inside.
New parts are: Body, chassis, the shock bodies and tower, wing and the one piece wing support beam, radio tray, centre diff supports and gearboxes to accommodate the larger diffs, now supporting LW internals. Speaking of the diffs, a limited slip diff option is in the works.
The setup settings are rationalized and while there's less choices they work great and the new parts don't spoil anything the old parts were good at. It was a win-win scenario. The buggy is lighter by almost 200gr. As many important parts changed (read chassis) there is no cheap way to convert a 7 to an 8.
#43
I saw Robert testing them at the Euros in Sweden. He went back to the regular cap - not sure if because it was supposed to be tested "secretly" (it was during practice or qualis) or he just prefered the regular shock.
#44
Alluminum part????
Schock total new or only body??
Center diff support similar mgt7 ??
#45
