Like Tree346Likes
Mugen MBX8
    Hide Wikipost
Old 05-31-2019, 05:05 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX8
Last edit by: E1 Diablo
E2025 - MBX8 Worlds Edition - April, 2019
MUGE0240: Wide Offset Wheel Hubs 1mm 2pcs; The 1mm wide offset wheel hubs will increase stability and cornering.
MUGE2146: Inline Front Uprights; The E2146 inline front uprights have smoother steering compared to the stock E2147 trailing front uprights and work great in high traction conditions. E2146 uprights can be used with both CVA and universal style driveshafts.
MUGE2168: -3mm Front Upright Arm; The -3mm front upright arm improves the initial steering response and make the vehicle more stable through the middle and exit of the corner.. The new upright arms also reduce bump steer and make the vehicle more predictable in bumpy conditions.
MUGE2235: 46T Spur Gear; The 46 tooth HTD spur gear provides a great balance of acceleration and top-end speed.
MUGE2252: 12T Pinion Gear
MUGE2254: 42T Conical Gear; The optional 12T bevel gear when used with the 42T conical gear will change the final drive ratio and increase acceleration.
MUGE2260: Center Joint Cup.
MUGE2261: Center Front Dog Bone (84.5mm)
MUGE2262: Center Rear Dog Bone (115mm); The front and rear-center dogbones for the MBX8 reduce friction from the stock universal driveshafts. Less friction will give the vehicle a more efficient drivetrain, increase acceleration, and provide more traction. The dog bones are lightweight, durable, and will increase traction.
MUGE2428: Rear Wing Stay +15mm; The +15mm wing mount has more adjustment and will help increase mid corner rotation and be more stable in high speed conditions.
E2021 - MBX8 1/8 Nitro Buggy Kit
Chassis:
The MBX8 chassis features a new design that improves traction and stability in bumpy conditions and on the exit of corners. The steering post are also keyed into the MBX8 chassis for easier maintenance.
Differential & drive train:
High Traction Differentials are included in the MBX8. The Mugen Seiki HTD provides increased acceleration, longer runtime, and more consistent handling. The HTD's also increase stability, traction, and improve handling in bumpy conditions. The HTD has a new larger volume diff cup to increase consistency during long main events. This makes it easier to time rhythm sections, better in bumpy and low grip conditions, helps to increase traction, and increases fuel mileage.
The new gearbox makes allows you to remove and service the differentials without detaching the suspension arm mounts. Easy access to the front and rear differential.
New straight cut 13T bevel gear & 44T conical gear. The new straight cut bevel and conical gears increase acceleration, runtime, and efficiency. A free and efficient drive train will also increase speeds while cornering.
Light weight one-piece wing mount:
The new lightweight one-piece wing mount lower the center of gravity. The position of the wing and wing mount is optimized to improve the performance of vehicle. The height of the wing mount is adjustable. This allows you to control the down force on the rear of the vehicle by simply raising or lowering the mount on the shock tower.
Light weight high down-force wing:
The new IFMAR legal wing is lightweight and provides amazing down force and cornering. The underside of the wing uses a new design to reduced weight and creates additional down-force.
Suspension:
New suspension mounts. The FF/FR/RF/RR are new for the MBX8.
The front and rear lower arms use a new impact resistant material for increased durability. The new arms are box-shaped and include arm stiffeners to reduce flex and increase durability. Adjusting the hardness of the lower suspension arms is now possible. This allows you to fine tune the steering and traction from track to track. CFRP plates will be released as an option part.
Center differential mount & plate:
The center differential mounts use a stiffer material and has a new top plate to reduce chassis flex and increases clutch bell, spur gear, and clutch bearing life. The reduced chassis flex also provides more consistent handling in all conditions. The top plate design also makes it easier to adjust the brakes and easier maintenance.
Enclosed Battery box and updated carbon fiber radio plate:
The MBX8 still uses a flat 2S Lipo or Life battery, but the receiver battery is now enclosed in a molded battery box. The battery box allows for quick and easy access to the battery. The molded box also helps protect the battery from hard impacts. The battery box is mounted to an updated carbon fiber radio plate.
Other new parts and upgrades:
Body, Clamping Servo Saver Nut, F/R Shock Towers, Front bumper, Front center and rear center universal joint.
Mugen Seiki MBX8 Manual
Print Wikipost
Old 02-26-2018, 11:45 AM
  #421
tom1974's Avatar
stanleyw808 likes this.
tom1974 is offline
Old 03-01-2018, 11:54 PM
  #422
dameetz's Avatar
I m building my MBX8 and notice the center diff gear has a bit of wobble like it does not spin true, is this normal?
dameetz is offline
Old 03-02-2018, 10:47 AM
  #423
Originally Posted by tom1974
What is the advantage of this bones ?
ddick is offline
Old 03-02-2018, 11:19 AM
  #424
tom1974's Avatar
I would like to know it too
tom1974 is offline
Old 03-02-2018, 12:54 PM
  #425
captain america's Avatar
Can you take a short video of what you think the problem is? Hard to differentiate between builder error and actual product defects merely from text.
captain america is offline
Old 03-02-2018, 01:56 PM
  #426
8T
8T's Avatar
Check to make sure that the diff cup is seated correctly against the gear. There is some flash on the diff cups that make it harder to seat them against the spur. The flash is located around the outside edge of the opening of the cup.
8T is offline
Old 03-03-2018, 12:30 PM
  #427
Trader Rating: 18 (100%+)
this bladders does not deflate
Where can we purchase these bladders? If not these which ones do you recommend getting over the stock bladders?
cubandiaz is offline
Old 03-03-2018, 02:19 PM
  #428
tom1974's Avatar
tom1974 is offline
Old 03-03-2018, 02:23 PM
  #429
tom1974's Avatar
Look Facebook
Ultimate racing
https://www.facebook.com/modelixracing/
tom1974 is offline
Old 03-03-2018, 02:56 PM
  #430
Thats not normal. Should spin fine... could be the build error?
carterena is offline
Old 03-03-2018, 02:58 PM
  #431
What weight (roller) do you get from MBX8?
Old 03-03-2018, 03:33 PM
  #432
HaulinBass's Avatar
Trader Rating: 16 (100%+)
dialed rc hobbies has the ultimate bladders
https://dialedhobbies.com/component/...oduct_id,2492/
HaulinBass is offline
Old 03-03-2018, 09:34 PM
  #433
Watch Adam Drakes MBX-8 diff build video on youtube
Chris Reilly is offline
Old 03-04-2018, 02:07 AM
  #434
tom1974's Avatar
You do Not use Shim in The differential under the Big gear
tom1974 is offline
Old 03-04-2018, 06:37 AM
  #435
dameetz's Avatar
Got it sorted, change to another diff case and the problem is gone. The diff case has some deform, the top part is not flat, I can see this when I spin the case only without the gear.
dameetz is offline
