Nitro finger destroying servos? >
Old 11-18-2017, 10:58 PM
Trader Rating: 21 (100%+)
Default Nitro finger destroying servos?
Hey guys I’m having some issues, I’ve been driving rc awhile and always used my m11 m11x without issues, i had a couple options else where tried them didn’t like the ultra response short wheel feel with most so I stuck with the smooth feel I know and I got a m12. Few years went by and I never used it because I was racing bikes so I know the m12 is older but when I used it I had 2 servos go bad in like 6 drives. I’ve recently been driving and when I was with my buddy he noticed my wheel had some major spring, when I turned the wheel and let go, it rattled the steering Servo just like the controller wheel viciously vibrates back n fourth for over a second or two. So we turned on a screw deep in a hole to adjust tension but this radio was a refurbished controller so it didn’t change much, can I fix this somehow?
Also the whole set up was completely crazy when I started it, literally took JQ to work on it to get it to where one side turned as fast as the other on steering settings, but I know it’s still way outta whack! I’m so confused n love the feel of it but know my settings are way off, if anyone can help me get this radio feeling right with some settings I would be greatful. It’s in a Losi 8 3.0 t 4.0
I call this nitro finger because we all started out as goons letting go of the steering wheel after every turn instead of controlling it all the way threw.
Matt Piva is offline
Old 11-19-2017, 07:06 AM
is it possible you have them trying to turn past their limits? that will destroy a servo pretty fast. gotta pay attention to the limits of the car and adjust the end points on the radio.
burnnitro is offline
Old 11-19-2017, 02:00 PM
Pot some pics of the config screens please.
30Tooth is offline
Old 11-19-2017, 02:17 PM
Will do, any specific I should take a pic of in settings?
Also another reply, I almost always set my end points every drive because after a drive I will completely kit my car, every time. So end points get re set Incase of changes. I know itís over board but I feel my cars have stayed together because I do this and I can catch problems rather quick. But lately Iíve found a lot of crippling set up mistakes in my radio and my brake linkages, still doesnít add up to my steering servos issues. Had a 7955 go first day, then a 7950, first one stopped working after it slowed down as if a battery died and the 50 was weird, took a 20 minute driving break n came back to drive n the Servo never turned on. Very random failure cause it seemed fine.
Old 11-19-2017, 06:19 PM
EPA mainly, that' the only one capable of causing issues (and abs).
It is possible the Rx is causing havoc, had one futaba rx from a friend that took out my beloved team orion 1308 when we were testing what's going on with his servos. if you have access to a multimeter check the lines, if the signal has around 3-4v it's normal so more than that (full voltage for example) isn't good.
Also, did the servos got hot? I would send the hitecs to hitec usa, the costumer service reviews here are tip top.
30Tooth is offline
Old 11-21-2017, 10:43 AM
wydopen's Avatar
you should be able to clear the model and rebind..that will put you back at all the default settings..
wydopen is offline
