Ofna Starter box question >
Like Tree11Likes
Old 11-17-2017, 03:23 AM
hillbillyrcer's Avatar
Default Ofna Starter box question
I bought a old Ofna 10250 1/8th starter box and it has the 12v 7ah battery in it and it is bad but cant find a part# or Model# of the battery so i can order a new one.
Does anybody know what kind of battery it has in it??
hillbillyrcer is offline
Old 11-17-2017, 03:24 AM
also need info on charger for it...
Old 11-17-2017, 03:32 AM
sickpuppy1's Avatar
Trader Rating: 32 (100%+)
I've been using a 4s battery in mine for 5 years now and it still works like a champ! I realize its listed as a 12 volt, but its been fine at 14 volts. And man does it have power! lol
I borrowed the 4s at a race when my OEM battery failed. After that I bought a used 4s off this site because it wasn't good enough to race anymore.....still using it. So if your charger will do 4s, that's all you need .
hillbillyrcer likes this.
sickpuppy1 is offline
Old 11-17-2017, 05:01 AM
ozziii's Avatar
I've just changed to a 4s LiPo in my box, was using 12v then changed to a 13.2v 4s LiFe, it was much better than 12v, but it puffed after a fair while & I was back to 12v, could hardly start my buggy at times. Decided it was time for a LiPo, haven't tried it on the buggy yet but it certainly spins much faster. $40 from HobbyKing well spent I think.
Go LiPo.
ozziii is offline
Old 11-17-2017, 05:59 AM
UrabusDenis's Avatar
Any Hobbyking 4S LiPO, you can find adequate ones around 20$. I have old 5000 mAh 20 hardcase ones from my ebuggy days, works great
UrabusDenis is offline
Old 11-17-2017, 07:09 AM
Hi Hiilbillyrcr, If this is the blue starter box with the silver top plate all you need to do is find a electronics supply place and look for a 12volt 8ah lead gel cell battery and I found a charger for it at a hobby shop or you could look online for Hanger9 12 v 600mah charger. I have used this setup for years and it works great for me! good luck Michael
AHR43 and hillbillyrcer like this.
stoney452 is offline
Old 11-17-2017, 07:23 AM
ozziii's Avatar
Yep thats the one I got, 5000mAh, 20-30c hardcase, costs a bit more in Australia, $33 for battery & about $8 post.
ozziii is offline
Old 11-17-2017, 07:42 AM
lipo in the starter box is the best. heck my old box with a 12v lead acid had trouble starting a .12 for a 1/10 serpent touring car I had.
I have the truggy ofna box and run lipos in it. best idea ever.
burnnitro is offline
Old 11-17-2017, 08:06 AM
i found the battery but i am finding out the replacement rubber drive wheel is no longer sold.
so i guess i will use it the way it is off my car battery untill the wheel wears out and then buy a new starter box....
Old 11-17-2017, 08:10 AM
check ebay. there was some on there not long ago. I found a new belt for mine from a company out of korea on ebay. only belts I could find. it sucks ofna closed. their blue buggy/truggy starter boxes are great. I have a new wheel but I'm not sure if I'm willing to part with it.
Old 11-17-2017, 03:07 PM
i have already checked ebay.... Thanks for the info i havent been in the hobby for a while...
Old 11-18-2017, 07:05 AM
ozziii's Avatar
The OFNA blue box wasn't made by them, just re-branded like their other products were.
Might be able to get parts from the UK through CML, its the Fastrax box,
FASTRAX TRU-START BUGGY/TRUGGY STARTER BOX #FAST561
Also, there is another box that is nearly the same, internals are virtually the same with twin 775 motors & the box is slightly different, thats the one that I have. It works great. I did have to replace the power switch early on though as it had a 10amp unit, now it has a 20amp unit with no further issues.
This is the other box, again, its in the UK.
Fastrax Power-Start Universal Starter 1/10th & 1/8th Box(Black)
This is mine, same as the black Fastrax box, probably not quite the same quality as the blue box but not far off.
I found this website (NitroRCX) a while back that sells the same sort as mine, although now it looks like they are out of stock.
Starter Box
On the NitroRCX facebook page it says they are in California so it might be worth contacting them, they may be able to get more or have parts which would also fit the blue OFNA box.
ozziii is offline
Old 11-18-2017, 07:13 AM
ozziii's Avatar
Q-World is the other brand I was thinking of that has the blue starter box, that may be the manufacturers name, I have seen the blue box sold under the Q-World brand on the net a while back, think it was Ebay.
ozziii is offline
Old 11-18-2017, 07:22 AM
Starter Box
Not the box i have.. mine dont use twin motors or a belt.... Ofna 10250 is the part number of my box...
Old 11-18-2017, 12:04 PM
Trader Rating: 194 (100%+)
Your box is the one big motor type, I tried a 4s lipo in it and found that when it started up it would just twist the motor around in the mounts, even had hose clamps on it and still would twist it up, so I went with the dual motor ones, atleast they cannot twist, but might still have it around if your interested, pm me if interested. Just not a good design for a starter box, just lacks the necessary torque to start motors.
Troubles Dad is offline
