HobbyPLEX Spec Porsche Cup class!!
#17
So how long does the battery last in that car. Has anyone actually seen how long the car will run? Just curious.
#19
thinking of getting team together for the Endurance race. and would like to know what to expect from the battery, because I bet the stock speedo does not have a lipo cutoff. Maybe it does? I have not really looked up the speedo. Is fairly slow like VTA slow or slower?
#20
Just looked up the Car and speedo. it actually is Either brushed or brush less capable. It does not Suport LIPO cutoff. Just some FYI.
#21
https://www.tamiyausa.com/pdf/manuals/45057ml.pdf This is a link to the esc, it does in fact have a low voltage cutoff. Slower than vta, and I wouldn't be surprised at 30 min or more of runtime.
#22
it says low voltage for Life pack. 4.8 volts. that will not work for lipo.
Protection systems: overheat, overload, low voltage to 4.8V (LiFe battery only) Note: Does not support LiPo 6.0 voltage cut-off
#24
We ran them last night, and they do get a bit warm even after a short race. More testing will definitely be done as we are still over a month away.
Also TimK, you are right on the lipo cut, thats a bit unfortunate. I guess you will just have to either time your runs or just pull it once power drops.
#26
Tim Ski
#29
Honestly so far the lipos have fit tight enough in the chassis that we havent had any issues with them. Just like you stated, they are too big to fit the battery end piece onto, but Ive yet to see one come out, or even move. If you wanted some sort of added assurance you could either rig up some sort of rubber band or O ring style strap to keep it pushed in, or if its loose at all, put a piece of foam inside the chassis.
I guess this means battery changes will be fast.
