what would happen if?
Old 01-08-2014, 03:50 AM
Default what would happen if?
Wondering would happen is you hooked up a 18v battery from a cordless drill to an RC car.
MR ELECTRIC1972 is offline
Old 01-08-2014, 06:14 PM
it would stink!
Tannhellyea is offline
Old 01-10-2014, 09:11 AM
Orion_2kTC's Avatar
Toast.
Orion_2kTC is offline
Old 01-10-2014, 05:08 PM
If your esc is a 4s or high capable it would be fine. It would look funny, but sure it would work.
bhilly82 is offline
Old 01-10-2014, 07:08 PM
WILDWILLIE 9's Avatar
Craftsmen used to sell a toy car that ran on the same lithium battery that the craftsman 18 volt drills and portable power tools use. If sure if your esc can handle 18 volt and the battery has a positive and negative terminal; your car will run.
WILDWILLIE 9 is offline
Old 01-10-2014, 07:32 PM
PnchoPwr's Avatar
Trader Rating: 19 (100%+)
You would have to gear accordingly. If your esc could handle the power, it will run like a bat out of h*ll. You figure a 6S battery is around 22.2 volts, and they make stuff that will run that. 18 volts is just under what a 5S battery is rated.
PnchoPwr is offline
