dex210 setup
Old 05-09-2013, 05:01 AM
Default dex210 setup
Just picked up dex210 last night. Need suggestions on setup. Rear or mid motor? Shock oil, gearing, battery plan on putting a club Novak system and running it in stock buggy. This is my first kit. Can't wait to get it on the track.
MR ELECTRIC1972 is offline
Old 05-09-2013, 05:04 AM
Mxer59's Avatar
Trader Rating: 114 (100%+)
This has a lot of useful info for that car.
http://www.rctech.net/forum/electric...10-thread.html
Mxer59 is offline
Old 05-09-2013, 05:18 AM
Rear motor for sure
evader-fan-69 is offline
Old 05-09-2013, 06:21 AM
Orion_2kTC's Avatar
Another excellent resource http://www.petitrc.com/setup/durango...ngoDEX210.html
Definitely rear motor unless you're running on a carpet track or a clay/dirt track with insane grip.
Orion_2kTC is offline
Old 05-09-2013, 09:53 AM
Heavy B's Avatar
Trader Rating: 18 (100%+)
If you plan to run stock, I would look into some RW spur gears. The 87 tooth kit gear will not get the gearing you need for stock. I would look into getting the 69 tooth spur for stock racing. Personally, I've never ran the kit springs as those are primarily for mid-motor set-ups. I prefer to run lt red all the way around with 2-hole pistons. You can always look me up at the track to bounce ideas off of for this car. I run both the 2wd and 4wd Dingos.
Heavy B is offline
Old 05-10-2013, 09:43 AM
Thanks everyone finding a lot of useful info on those links. Heavy B I will be at the track tonight. My name is Chris I run the slash with the red and yellow scalpel body and the red and yellow xxxt in stock truck. Hope to see you there. "SHAKE AND BAKE!"
