Losi LST 3XL-E
#316
Tp motor
Hello hows the new motor working for you Jharper? Is it a 4050 2310kv.
Thanks, Michael
Thanks, Michael
#317
#318
Thanks for update.
Michael
Michael
#319
#320
#321
#322
I am thinking the reason Horizon has the 3xl-e on clearance is the replacement Losi's will have the Spectrum smart technology.
#324
Yes, not sure how longer this is going to be around. This was a decent truck, but think alot of folks were turned off by the initial price of $700-$800. My stripped the rear diff on the first turn and bent 2 axles on the second. I was turned off by that. I heard they were able to fix some of these items in the months after release, but that didn't help me much.
I like the look of this rig and I thought it handled well, but for $700 bucks back in the day...there were better options (MT410 using budget electronics, any of the 1/8 6s Arrma models, and so on...).
At $500, I think it's a deal, but I also see support going away for this rig in the near future.
#325
Losi 3xle diif oil setup?
Hi
whet is the recommended dif oil
front,center,rear setup for my losi 3xle
thenks
thenks
#326
Chassis flex?
I took a high seed jump and the rear center drive shaft popped out of the center differential after a bad landing. It looks like it should be longer. Anyone else have this issue?
#327
Looks like I busted a diff and that was what caused the drive shaft to pop out as the rear duff became locked. I had the diffs shimmied but only the spider gears and they look ok but the larger gear is what broke.
#328
Can you E-LST guys check out this truck and tell me if it's good?
https://www.ebay-kleinanzeigen.de/s-...8821-249-15777
It's a converted XXL-2 I think. I'm a nitro guy but wouldn't mind trying an E-LST since I still have a nitro LST2 and tons and tons of parts. Thanks.
#329
It looks to been well taken care of and is in good shape.... I have had no experience with the conversion LST's. Had a few LST2"s and they rock.
#330
Same here basically. I've had two nitro LST2s and loved them. Sold one, still have one, but it's ragged out. I have a ton of spares though.
Looks to me like the ESC and lipo locations should be switched for better balance? Is that straightforward enough?
I would only be running 4S, maybe 5S... And not extreme bashing either. Just blasting up and down the road for the most part...
