Lightning GT - Pro >
Lightning GT - Pro
Lightning GT - Pro
Old 01-10-2006, 09:20 PM
o_it_burnz's Avatar
Default Lightning GT - Pro
did some lookin around to see what the diffrence was between the two since they use from what i can tell the same layout. all that is really said is that the GT has a little more ground cleareance and stock tires and rims are diffrent. i am sure the pro has diffrent quality of certain parts since it is the "pro" version. Is that basically the diffrence? i tried to look up a part sheet but i dont know where to start so i quit after a little bit just to compare part numbers. if ground clearance is really it couldn't you change the shock setup and to lower the CG by using diffrent holes in the Aarm's and shock towers? Anyone out there with some experience or knowledge of these fine machines feel free to chime in and set this newb staright ( really, chime in ) For some reason this truck (GT) catches me more then the RR or Pro so i am trying to gather as much info as possible before i make the jump into nitro but HB's website leaves something to be desired.
o_it_burnz is offline
HTML code is On
