LOSI LST RPM Adjustable Upper & Lower A-Arms >
Old 04-01-2017, 02:34 PM
  #16
serafin's Avatar
Default AXLE NOT LONG ENOUGH
After running my LST with the RPM ARMS I noticed some clicking noice and couldn't figure out where it's coming from. Then after more test runs. I see that the left rear axle is barely inside the diff cup. It's not bent or anything.
Then I put the stock lower a arms next to the RPM ones. And it seems like the RPM lower A Arms are a bit longer than the stock.
Anyone else have this issue?
If so any fix for this?
I just swap the rear lower A Arms for now. Don't want to waste these lower arms since it took forever to hunt this down.
serafin is offline
Old 04-03-2017, 08:01 PM
  #17
serafin's Avatar
Just Noticed the RPM arms a re a bit longer than the stock arms,
now the left rear axle is barely hanging in the Drive cup..
any suggestions?
serafin is offline
HTML code is On
