Throttle trim doesnt work
Ive tried adjusting the throttle trim, it doesn't do anything at all... I cant get my Savage 25 Ltd. Edition to start with the RX on because it's closing the carb.
I took off the fitler, with RX and controller on and turning the throttle trim all the way around and it does nothing. The carb doesnt move the slightest bit. If i press the throttle it opens like normal but the throttle trim doesnt make the carb move AT ALL! Is it broken? |
it might be that the endpoint adjustmnet is set too far to the closed throtlle possition and it takes to much of a movement from the servo than the trim will provide.. or the sub trim may be set too far aswell, check all the settings you can.... it should be one of those 2 things.
if that doesnt work..take the linkage off the servo recenter the settings in your radio to neutrl, 0, and hook it back up and reset it |
| All times are GMT -7. It is currently 09:25 AM. |
