problems turning right
After fixing the parts I broke in my crash i went to check the steering I found
a new problem it turns fiine going left but only a inch or 2 to the right .Ive checked the gears in the servo the steering arms every thing but no luck .Can anyone help me out.by the way i have a savage .25 with new team blue star shock is that the problem. |
goin to you stering settings on your radio and set those all to o (neutral) and unhook your lingages on you truck and make shure there all nuetral adjustments/settings, then hook everthing back up and set your stering trim so it goes strait, endpoint adjustments,and your dual rate
thats all if if it was goofed before it was broke, if it was fine before, you might just want to play around your end point adjustment on your radio , or your linkage adjustments, untill it turns the same both directions. |
reply
You are the greatest I did everything you told me to and it worked thats why
i love this froum. thanks |
| All times are GMT -7. It is currently 10:50 AM. |
