Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 12-30-2005, 10:27 PM   #1
CocoaNitro's Avatar
Post rock crawling
has any body tried or has used brushless motors in their rockcrawlers? I am new to electrick monster trucking and wish to be informed before i jump into it.
CocoaNitro is offline   Reply With Quote
Old 01-01-2006, 01:44 AM   #2
dracy69's Avatar
Send a message via AIM to dracy69 Send a message via Yahoo to dracy69
use the motor off the electric start of an expedition.....that should move your truck nicely.
dracy69 is offline   Reply With Quote
Old 01-01-2006, 04:26 AM   #3
Mvp
Mvp's Avatar
I've yet to see it, but from what I've heard they dont carry as much torque as your average brushed motor(mostly high RPMs). Personally I'd just stick to standard motors...
Mvp is offline   Reply With Quote
Old 01-01-2006, 09:28 AM   #4
dracy69's Avatar
the summit racing protorque starter motor has 220 ft lbs of torque....thats more then a honda civic....dont you want your r/c to have more torque then a civic?
Old 01-05-2006, 12:48 PM   #5
Mad Hatter's Avatar
head over to rccrawler.com, some ov the guys there have run brushless set ups in their crawlers.
1987 Excite Bike Champion
Mad Hatter is offline   Reply With Quote
Old 01-10-2006, 08:53 PM   #6
lastresort's Avatar
Default Brushless
I've put one in a txt with a gear reduction and it did fine.I'm finishing up a tube chassis and I'm gonna try an outrunner axi motor with a mamba esc.This is what some of the guys are doing on rccrawler.With the outrunner you don't need the reduction.With the novak stuff a reduction is a must.Hopefully I'll have my outrunner by friday.I just got my tubechassis put together I will be trying out several setups I have a novak 5800 that I will start out with with the reduction and I'm gonna try the mamba speedo and the outrunner as soon as the motor shows up.
lastresort is offline   Reply With Quote
Old 01-18-2006, 06:19 PM   #7
lastresort's Avatar
Default Brushless
I have a novak 5800 in the tube project I just got together.Its on a 3.5 to1 reduction and hooked to a emaxx trans.It works flawlessly.The setup does draw over 65 amps under full load.I've been running a 2 cell lipo and it kills it pretty fast,but its only a 1250 mah.The truck never has trouble bogging down at all.It performs better than my clod with brand new lathes on 6 cells.I'm gonna parallel another 1250 pack to extend runtime and keep up with the amp draw.
Rock Crawling Newbie Here Biggun Electric Off-Road 14 03-29-2008 04:30 AM
R/C ROCK CRAWLING REX4112001 Electric Off-Road 2 04-23-2007 05:58 PM
Rock Crawling? bohnen Alabama Racing 0 02-15-2007 04:37 PM
RC Rock Crawling Drift_Buggy Australian Racing 3 02-13-2007 08:13 PM
RC Rock Crawling omalley Minnesota and North/South Dakota Racing 2 06-07-2004 12:20 PM
HTML code is On
