New to me lst roller brushless converted
#46
dunnop what batteries you running, but here's what i did with the e lst tray
http://www.rctech.net/forum/monster-...ust-see-6.html
#47
So here is the almost completed truck as I am waiting on a replacement a arm as I gather the lst2 suspension. Just received the new 8mm axles and 20mm hexes. Should be up and running later this evening, here is the battery tray and gear cover.
That's running a 3s 7200mAh and a 2s 7200mAh for 5s total.
I also drilled new holes in my old emaxx body and will post some pis of it completed later.
#48
I can not see the pictures?
Keep in mind that if you want to use the LST2 axle carriers with the LST1 arms you need to get a couple of washers to make up for the with of the arm.
RPM makes them, but a couple of 3mm washers may work to, since it is just a temperarely solution.
#49
I'm going to actually have the hubs, carriers and arms soon from the lst2
#50
Ah, since I could not see the pictures, I thought you already had them since I thought you wanted to run the 8mm axles.
The car looks good!
The car looks good!
#51
Thank you, ya I have no clue why they didn't work the first time. I ran it for the first time and within 3mins blew something in the rear diff, I assume the pin in the diff so I'll have the new HD diffs and some hpi pins on order soon
#52
I do not understand that, sorry.
What did not work?
Or did you think the 8mm axles would work on a LST1 suspension before we explained it?
What did not work?
#53
I was referring to the pics not working. I was just waiting to get all the lst2 suspension and axles before it's installed on the truck, I wasn't going to mix the suspension
#54
Aha, sorry, My English is not that good, sorry.
Are you waiting for the LST2 suspension to drive, or are you already driving the car?
#55
Guy I bought the truck was giving me the lst2 a arms and hubs, but that was 3 weeks ago and the usps has lost the package.......no insurance so it may be a total loss and I'll have to add that to the order too with the diffs. I have the new axles and 20mm hubs already. Just need some a arms and hubs and also some new wheels, plan to run the stock XXL2-E wheels n tires.
#57
Alright guys, my stuff is boxed up for our move next weekend but I just got in my lst2 suspension, and I already have the axles and hubs nip ready to be put on and it's killing me!! All I need now is the rip the diff apart to see what's going on with. If anything I'll go ahead and order the HD diff parts and just do it now and it won't be a worry later, than I'll have me a nice bad ass lst!!
I'll have to try 6s if I ever get me another 3s lipo.
#58
Right in the middle of moving and was able to snap a quick photo of the truck with its tires and old body from another truck. Enjoy!
I have new HD diff parts on order now to the new addrest when I get there. Waiting on some other funds to clear then I should have some new wheels n tires on order. Give me a few weeks and she should be finished and rdy for a bash kickin'
Edit: now I've seen a few lst's with the rear shock flip, does this do anything to better handling or some type of improvement.....or simply just for a look?? I like it tho
#59
#60
not sure if this is the thread about the shock flip
http://www.rctech.net/forum/monster-...ification.html
