So torn. X-MAXX or XXL2-E
#31
I would say stay clear of a xmaxx till te aftermarket pics up. I've done a lot to mine but it is currently called the shelfmaxx by my friends and myself. Every time it's out it either eats up a spur gear, shears axles pins or cracks a wheel ever farther. It's a fun truck especially with different gears and a new esc but I can't remember the last time it made it completely through a set of charged batteries.
#32
Update: I did end up with the x-maxx, and love it. Best rc I've owned. Added fans, 18t pinion, hobbywing max 6 esc and it's awesome. Can't wait until the good upgrades start Rollin out. Lots of runtime on it and only broke a steering rod.
#33
I like the X-Maxx, but the model is too fast for it's durability. I would gear it down to it's durability limits to avoid breaking expensive parts.
#34
33mph it's too fast. The parts that have been common to break are usually result of bad landings.
#35
Traxxas=Plastic
Plastic=junk
So what did we learn?
Losi all the way
Plastic=junk
Losi all the way
#36
While in past yes the Traxxas use of plastic could be fustrating. But after 50 runs on my X. The plastic parts have yet to be an issue. Couple of diff ring gears, 2 axles.
Can't say anything about the new losi. Haven't seen one. And real good chance that, unless I buy one, I will never see one. From what I've read it sound good.
And while I've found a few that have disliked the X after owning one. Majority are really good with it.
#37
@Billy Kelly
Agreed. Some peeps like plastic, others don't. I perfer the alum/ steel components on certain cars, but on others, it better be plastic so it replaces easy.
#38
The title of this thread got me! I'm in a similar situation only I can't decide between the Xmaxx or building a Tekno Truggy with MT tires. Either one would cost me about the same so the money is a wash. The sheer size of the XMAXX is what's attracting me. I just bash on my property which is why I like MT's because of their ground clearance. I just have too many memories of my Tmaxx stripping diff gears once I upgraded the power in it. I don't like the talk of guys stripping gears in the Xmaxx with stock electronics. I just don't wanna end up headed down the road of, once you upgrade the speed control, diffs, and driveshafts it's an awesome truck!
#39
Most of the stripped diffs seem to happen from bad landings or try to do speed runs. Here's what mine looked like.
https://youtu.be/UoPdsysBCrE
#40
I've had almost completly aluminum redcat Mt and baja 5b. Looked nice and really awesome vehicles, but I'll take the x-maxx over them both.
#41
Dream state, did you upgrade the ESC due to failure, or just cause you wanted to? I ask, because I've been carefully monitoring the interwebs since Traxxas added the fusible link, and to my knowledge I haven't heard of any ESC's that came from the factory with the fusible link going up in smoke on 6s. Users that added the link to theirs that didn't come from the factory with one may have an issue, but not installed from the factory. It's my hypothesis that they made and internal change to the new ESC's, wish I knew what they did, but happy they did it, if they did.
Thanks,
Trout
#42
Trout. If I remember right he swaped ESC by choice. Right after getting the truck.
#43
I've run the SMC 9000mah 11.1 packs around 30 times so far thru my
xmaxx that came with factory installed fuse-able link esc ,So far no problems ,
Did install the Hot racing fan over the motor , only problem I have is that I can't get the gps module to show the speed on the android app , It's led shows green so its connected , I've reinstalled app but still no luck getting it to work .
Still waiting on my tbone racing bumper and wheelie bar
One thing I've noticed is that it wheelies more when tsm is set to 20% as compared to being off , when its on I can wheelie on demand , figured it would be the opposite
#44
#45
The shear size of the xmaxx is impressive. But I will say from the few I've seen I'm not really impressed with their performance when compared to 1/8 scale trucks. I'm talking wheelies, standing backflips, speed, and jumping ability. If these stay popular long enough hopefully the aftermarket will remedy by making parts that will be able to live with 1/5 scale electric power.
