Losi XXL2-E
#1966
I understand totally and when I was sourcing the xxl stuff I could never get it all from one seller and I guess I got lucky with my spacing. All I remember was a old hpi package that all I could read was 1.5mm.
At least if I break there is an upgrade out there for me.
#1967
@rhino, thanks for the offer. I live in The Netherlands, are you from Europe also?
#1968
I forgot the stock losi XXL2e motor mount only accept 40mm diameter motors. So thinking about considering another mount. Will this work on a lst or lst 2e chassis.
Bekijk dit op eBay http://www.ebay.com/itm/332321533380
Or this one Bekijk dit op eBay http://www.ebay.com/itm/182714843286
#1969
@Wesleroy - No I'm in southern California and shipping charges would probably outweigh any savings I could provide you with.
Looks like either motor mount you are considering would work.
#1970
Oke thanks, is the stock lstxxl2e motor mount, accepts max. 40mm diameter motors or also 42mm? I found different answers on the internet.
I like this motor, wich i had run in a truggy but sold it. its. 42mm
Tenshock 1/8 X812L-2150KV Sensor Motor Truggy+Hobbywing XERUN XR8 150A PLUS ESC | eBay
#1971
Broke end off 2 slipper clutches now. What am I doing wrong.
So the first one broke
After a year of use. The second one broke as I was putting together the slipper clutch. I followed a utube video so I know I had all the correct parts lined up. I still had enough threads to use a different but. Then I went and set the gear mesh which I typically do through listening to it while moving the motor. But did paper trick this time and mesh was a mess so my hear what to hell. ans recommendRions on setting up slipper and gear mesh it would be greatly allrecaiated. Thanks
#1972
Bekijk dit op eBay Losi LST Motor Mount M3/M4 1717 Version Electric Conversion TEAM LST2 Brushless | eBay
Or this one Bekijk dit op eBay Losi LST Motor Mount *Titanium* Electric Brushless LST2 & XXL 1717 LOS04004 | eBay
#1973
Thank you. I decided to not convert my lst aftershock to a xxl because i already have the XXL2e. So i have to choose a motor mount wich works for the aftershock. Read some good things about rc monster stuff. So going for that motormount and battery tray. As for single speed hub i went with a new losi hub from lst XXL2e. Complete deal from DollarHobbyz with spur hub slipper.
#1974
New to XXL2-E and Losi- Where are the Aftermarket Parts?
Hey all, just starting to research the XXL2-E as a basher for me and my 11 year old daughter. We have 2WD and 4WD slashes that are highly modified and need a lot of TLC to keep running. Ready to take the leap to larger scale and I have been researching all over the map finally settling on the XXL2-E (started with DBXL-E, then Axial Yeti XL and now XXL2-E).
Hot Racing, RPM and Pro Line don't even list the XXL2-E in their model list. Can't find anything on Integy either. GPM has a few items. Where are you guys getting your replacement, aftermarket and hop up parts from? Or does everyone just stick with Losi parts? Or do most of the gas powered XXL2 parts fit on the E model?
I'm going to keep reading and researching before pulling the trigger and buying one but it seems weird there is so little aftermarket support.
Thanks for the help!
#1975
any good video of this truck ?
#1976
https://www.rakonheli.com/catalogsea...sult/?q=xxl2-e but i dont really think it needs aluminium or carbon upgrades. However i like the carbon plates.
I have the T-bone bumpers, they are quite big and maybe not as nice as stock, however they protect the front and rear good.
Also i like the yellow losi springs, Raven rc springs seems even better springs, however that was a bit to expensive to ship to Europe. The yellow springs are a big improvement. At first i was continuing breaking shock shafts, till i changed to yellow losi springs, wich are stiffer. Now i dont have problems breaking shockshafts al the time.
THis is my LSTxxl2e, yellow losi springs, 17mm hex with Louise rc tyres, Tbone bumpers, Proline GMC Topkick body.
Bodys for the HPI Savage HP fit the Losi. Bodys for the Emaxx or HPI e-savage are to small.
#1977
#1978
That is a nice looking truck.
#1979
Hello. I was wondering if someone could measure the long part of the chassis for me. I'm trying to order a Dusty Motors cover and want to get a good fit. Thank you.
#1980
Okay and I had some other questions I couldn't find in the thread lol
I have everything on the way and only went with two 3s 5000mah packs. I'm now thinking that is too small of packs? They seemed big to me, but I'm seeing others talk about 7000s and 9000s. Am I only going to get 15 minutes with these two packs?
Also I am intrigued with the X-Maxx. Have always liked to have a lot of ground clearance so I can fly through grass and fields. Without taking these stock shocks off and just adjusting them do you think I could make the Losi X-Maxxish with bigger tires? I don't want to destroy it's stability and ability to carve corners but I really would prefer more ground clearance.
Thanks for reading.
Thanks for reading.
