Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 06-30-2015, 08:28 AM   #1
Updating's Avatar
Default Wheel nuts keep getting loose?
My wheel nuts keep unscrewing and falling off. Basically, why do my wheels keep falling off..?
I recently installed desperado wheels on my Savage XS. I used the supplied flat Hex mounts. I wasn't able to use the stock wheel washers because they don't fit the inner bore of the wheel. I only have the wheel nuts on and they keep unscrewing. Is this because I'm not using washers?
If it is the lack of washers, can I get any washer at the hardware store or do I need to order something RC specific? Also could it be the wheel nuts?
Thanks in advance...
OTB - Old Trail Bashers
Get at us on youtube
Updating is offline   Reply With Quote
Old 06-30-2015, 08:30 AM   #2
Blue thread lock
2uzferunner03 is offline   Reply With Quote
Old 06-30-2015, 09:15 AM   #3
Hoese37's Avatar
Get aluminum serrated nuts.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-30-2015, 09:33 AM   #4
wittyname's Avatar
This and blue Loctite are the answer. Let the truck sit overnight before you run it . Make sure the wheel hexs have not stripped and rock out
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 06-30-2015, 10:06 AM   #5
Dstreelm's Avatar
i wouldnt use loctite on your wheels as it can gum up the threads and make changing wheels annoying...I would get flanged nyloc (nuts with the nylon insert) nuts and you should be good to go
Dstreelm is offline   Reply With Quote
Old 06-30-2015, 10:10 AM   #6
traxxas sells an aluminum serrated flanged nylon insert lock nut. they are quite spendy for what they are, but they are amazing. I would hunt down a set of them to see if they fit.
Josh
wilsonj1018 is offline   Reply With Quote
Old 06-30-2015, 10:12 AM   #7
skinned's Avatar
Thumbs up
this....
skinned is offline   Reply With Quote
Old 06-30-2015, 10:28 AM   #8
the incubus's Avatar
Trader Rating: 17 (100%+)
Best option…
http://www.teamassociated.com/parts/details/25217/
There are Low Profile ones as well but they are difficult to come across. Used to be more common but have faded slowly. Maybe someone will see the need for it because I've had plain serrated ones fall off a couple times when I KNOW they were torqued down firmly.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 06-30-2015, 10:32 AM   #9
klaymon's Avatar
Trader Rating: 71 (100%+)
These are amazing if they'll fit inside your wheel: http://www.amain.com/rc-cars/traxxas...ra1747r/p23099
I've used them on every off road car I've had. Never had one come loose.
klaymon is offline   Reply With Quote
Old 06-30-2015, 10:39 AM   #10
yep those are the ones I was talking about, my lhs charges 18$ for em LMAO ive bought about 8 sets..... might just have to stop shopping there...
Old 06-30-2015, 12:19 PM   #11
RotorTruck's Avatar
A dab of blue loctite.
-Brad
RotorTruck is offline   Reply With Quote
Old 07-01-2015, 08:08 AM   #12
The yokomo 4mm serrated nuts are low profile
HTML code is On
