Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 06-21-2015, 12:58 PM   #1
rigelkent09's Avatar
Trader Rating: 44 (100%+)
Default Minimum oil content nitro fuel for bashing
Our lhs has oddonel speed blend 20% on sale for $14 a gallon which also has only 7.5 % oil content, I'm mainly into bashing, I have traxxas revo, t maxx and slayer pro all have the stock 3.3 engine, will It ruin or shorten the life of my engine if I will run it with the said fuel? I need some input from you guys here before pulling the trigger on the speed blend which I think a very good deal, your comment is very much appreciated, thanks.
rigelkent09 is online now   Reply With Quote
Old 06-21-2015, 01:24 PM   #2
Hoese37's Avatar
No effect on longevity if you tune it properly. Less oil means less heat, better running and runtime, but a narrower tuning window.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-21-2015, 03:11 PM   #3
Wow, great info, I have tried a quart of 30% speed blend before and I did notice right away the temps, your right it runs cooler than traxxas top fuel! my problem was to get it to the right temp 250F. On a less oil fuel is it true that you have to richen both hsn and lsn if coming from a higher oil fuel? Thanks...
Old 06-21-2015, 05:58 PM   #4
Hoese37's Avatar
You will have to retune. I would give the needle a good full turn richer and start from there. If you run less oil it will have to run richer.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-28-2015, 11:48 PM   #5
Maxximize's Avatar
I prefer lower oil content in my engines. Byron's 20% with 11% oil for small blocks and Bones 30% with 10% oil for big blocks. I've tried some of the "Basher" fuel with high oil content and had tuning issues with it. Just re tune when you switch brands and nitor/oil content and you'll be fine.
"Punisher" LRP Z.28R Spec 3 powered custom T Maxx / Kyosho Mad Force Kruiser 2.0 / E Revo 1/16 Brushed / T Maxx 4910 (Original 1999 Pro .15, project truck) / HPI Nitro Rush (Original, project truck)
Maxximize is offline   Reply With Quote
Old 06-29-2015, 02:58 AM   #6
%10 give or take %1 is good. My experience with lower than %9 was not good..
With offroad bashing the tuning window by necessity needs to be broader IMO. For ex. just going from pavement to grass and/or dirt and/or gravel is all different in how it should ideally be tuned. Plus you've got big heavy tires, a clunky drivetrain, etc. IMO anyway...
-Team Associated RC8.2, RC8T CE, & SC8 with 1.) Argus A52/0801, 2.) RB Fire 11/2058 or 053, 3.) RB Blast V9/2045, 4.) Nosram RS.30RR/JP-4, & 5.) modded Nosram RS.21RR/086
-LST2 #1 with Losi 454 & LST2 #2 with Dynamite Big Red .28
-Ofna DM-1 with silver Mach 427/2047
-TT MT4 G3
Herrsavage is offline   Reply With Quote
HTML code is On
