Official PRO-MT 2WD 1:10 Monster Truck Kit Thread
#46
I just ordered one of these. Can anyone tell me what are the max dimensions for the battery? Also what pinion should I start with. I would like to run a ROC412 1800KV Tekin motor on 4s.
#47
Just received my kit. Along with my CF shock tower braces. Not too impressed with the fitment between the two pieces. Holes are off about half a hole.
#48
Well after a full weekend of bashing the truck I'm happy with it for the most part. I did bend one rear inner pivot pin. The pivot block is all stretched out too. Everything else held up well.
I looked for a new set of pins and a new pivot block but all I could find was a complete set of pins for $23 at Tower. C'mon Proline I don't need an entire set. It would be nice if I could buy just the rear set.
#49
The Traxxas ones do not fit?
Or a piece of a drill bit?
#51
I am looking to run a Savox 1256 without BEC. Do you think the CC mamba max pro will work?
#53
Weekend 2 of bashing saw a lot of big air and a broken rear stub axle. Tower says parts are "on order". Guess I'm out of commission until they come in.
I id try a 23T pinion with the 86T spur gear. It's a little too much. Temps were fine but it was just too fast. I'm going back to the 21T pinion.
ROC412 1800KV motor on 4S.
#54
I am just looking for the easiest way to get the truck up and running, that's all. Guess if I have use a BEC I will.
#56
I Like using BEC's, but that is just me.
A glitchbuster could help to.
But I would try it without a BEC, and if it does not work, buy and install one, or a glitchbuster
#57
Is there a factual issue YOU HAVE HAD ?
the 1256 has great torque, MM2 has adjustable BEC....Why run another? and why a glitchbuster?
Just new stuff to me need good facts
With what I have in this ride, whats a few $$ more?
#58
I personally do not have expierence with that problem, but I heard quite a few people who had brown outs with a Savox servo, and a Mamba ESC.
But that was in the MMP and the MMM1 v3 time, maybe the BEC in the MMX is better.
I would just drive it, and if you seem to have brown outs, get/make a glitchbuster or a BEC.
No need for fixing a problem that is not there
#59
#60
Well, on the other hand I think a seperate BEC ( I like the Castle 10 amp one ) never hurts..
