Axial yeti XL 1/8th scale
#61
I've only seen some "homebrew" sway bars so far, not the official kit, but regardless they seem to eliminate most of the twist. One video showed a wheelie on 6S instead, so my guess is that if you get it stiff enough then you don't twist any more.
#62
Yes, I would like to see real pics of the AX31029 part. From the picture on some of the online retailers, it looks nothing like a sway bar. However, the AX31029 is molded into the plastic. Plus it does not discuss Front vs. Rear. Does it include both?
#64
The 2 speed motor mount and transmission are "in stock" on Tower but I wonder if they come with documentation on the install? Plus, don't you need more hardware?
#67
#69
I just emailed Axial to ask. Not expecting much of a response but I guess we'll see.
Same with the rear sway bars, it's one part but no hint as to what else is needed.
#71
#72
Looks that i've blown the front differential. I've never dealt with a blown differential though. Basically I noticed the front wheels stopped spinning after a jump. The left and right wheels were bound, acting as if it were a locked differential. Took it apart and looking at the gears and cross pins I can't really tell that there is damage but sure enought when I put it back together there is all kinds of binding. I guess even the slightest wear on the gears will cause this? Anywho, only put 3 sets of battery packs through it. I did shim the pinions but I don't think that's related.
#73
Actually looking more closely, I'm wondering if I didn't bend the output shafts. They look ever so slightly off kilter. Would make more sense too if it happened immediately after a big jump where I landed on the front hard
#75
