Starting problems
I recently bought a tmaxx used from a friend. It ran well before i bought it. However, shortly after purchasing it i tired to start it up and after alittle toying with it, got it started. Once i get it started i let it warm up for a minute or two. Once its idled for a few, i hit the gas and it bogs out. I have tired to lean it out, but when i do that it wont start anymore.
Any ideas? |
Any ideas? |
Um, the .15 i beleive
Any ideas? Before you attempt to tune it replace the glowplug. First adjust the low-speed needle so that it is about plush with its casing. Once thats done adjust the idle screw so that once the brakes are surpressed you can see a 1.5mm gap in the carbies slider. Now tighten the High-speed needle in fully and back it out 2.5 turns. See how that works for you. Sean |
| All times are GMT -7. It is currently 04:33 PM. |
