-   Monster Trucks (https://www.rctech.net/forum/monster-trucks-46/)
-   -   S-Maxx Trans problems (https://www.rctech.net/forum/monster-trucks/79341-s-maxx-trans-problems.html)
maddnitro 07-28-2005 08:46 PM
hi Im trying to figure out the problem with my tranny, first of all after 6months of weekend abuse i was driving the truck and when I went to take off the trans slipped and then caught and took , of then it did it again and finally wouldnt catch, I noticed that the spur gear is turning however the trans is obviously messed, my friend said there was a pin that commonly went bad but when i split the case It seems like everything looks ok, but Im thinking its the slipper mechanism inside what are your thoughts??
Jon
smaxxman 07-28-2005 09:42 PM
1) Tighten the slipper.
2) Check your differentials
maddnitro 07-29-2005 05:43 PM
ok so your talking about the slipper on the spur gear correct? Havent checked the diffs Ill get into that , Im just confused on how everything worked when the motor was off, my question is when I spin the spurgear is the drive shaft suppose to spin? because I cant get it to by hand and thats why I think its something messed in the case of the transmission? :tire:
Johnathan 07-31-2005 09:03 AM
the wheels will only spin when the rpm of the spur gear is high enough, so keep that in mind. the spur also should spin when idling, though not at a high enough rpm to catch the tranny.
happy racing! :nod:
maddnitro 08-02-2005 04:40 PM
Kool thanks
sherrc51 08-24-2005 09:16 PM
set screw
Check your set screw. If that is not it thenit will be the slipper. There are 3 set screws to check. Two on each end of the tranny going to the diffs and the one for the 2 speed.
