a new fuel tank has made my savagre run better >
Old 07-21-2005, 01:55 PM
Default a new fuel tank has made my savagre run better
after $25 for a new tank i notice she starts up first try and runs much better then the old one
classic xl is offline
Old 07-21-2005, 03:11 PM
what tank did you get?
stampeder is offline
Old 07-22-2005, 09:21 AM
Default reply
just the factory tank because the hobby store i useilly go was sold out so i went a differnt store .
Old 07-22-2005, 10:57 AM
yeah the factory one w/ out the primer is much better and makes to motor run more consistent
mtx3racer is offline
Old 07-22-2005, 06:17 PM
Tonafio's Avatar
I need to know how do youguys get nitro to the engine without the primer???
Tonafio is offline
Old 07-22-2005, 07:00 PM
Default reply
its the same tank as i got with my .25 but is new
Old 07-22-2005, 08:25 PM
pink pac man's Avatar
i think you just put a few drops of nitro down the guts but im not sure.....
i saw my friend do it once but im not a nitro guys lol
pink pac man is offline
Old 07-22-2005, 09:21 PM
Team Duratrax's Avatar
Your old tank must of had a small hole in it causing an airleak.
So your old tank had a primer on it but your new one doesn't?
Sean
Team Duratrax is offline
Old 07-23-2005, 04:31 PM
Default reply
new tank is just like the one that came with my truck but is new and the new one still has a perimer
Old 07-24-2005, 10:06 AM
jonski's Avatar
Trader Rating: 315 (99%+)
To get fuel to the motor, put your finger over the stinger and turn the motor over a few times (before installing the glow ignitor). You should be able to see the fuel in the lines. Install the ignitor and fire it up.
jonski is offline
Old 07-25-2005, 05:24 AM
What happens if that doesn't work?
Someone suggested sucking up the fuel with your mouth and blowing through the pressure line. The pressure line method was unsucessful.
Any ideas how to pump that fuel to the carb? Im lost on this.
Sean
Old 08-23-2005, 08:58 AM
Horatio's Avatar
Sorry - but the tank with the primer is pointless. The primer is spposed to make it easier to get fuel to the carb prior to starting the engine. Unfortunately, it also allows air to get into the fuel line and causes problems. They all do it.
The thing is - no one needs a primer! Just blow down the pressure pipe and fuel will get to your carb. Then, a quick dab of a finger over the exahust (whilst spinning the engine) helps draw some more fuel if need be. This method primes any engine quicker than with a cheesey priming pump and it doesn't risk troublesome air leaks.
Horatio is offline
Old 08-23-2005, 09:02 AM
Horatio's Avatar
Sean
Even tramps know better than to try putting nitro fuel into their mouths!!!
Assuming you have fuel in your tank, just blowing down the pressure pipe will force the fuel in the tank to travel along the fuel line and into the carb. If your carb is set right, your engine will start.
DONT PUT NITRO FUEL INTO YOUR MOUTH!
It's highly toxic and can cause blindness.
Horatio is offline
Old 08-27-2005, 01:31 AM
I remember i blew the fuel line that hard my head turned into a tomato.
Anyway i've since found the problem though. The engine was worn down to the nickel inside the sleeve.
Sean
Old 08-27-2005, 04:14 AM
Horatio's Avatar
If you have to blow so hard your ears pop, chances are that your LSN (or possibly your HSN too) maybe completely closed off. This will prevent fuel flow and make the engine impossible to prime or start. It will also make your head turn into a tomato.
With the correct needle settings, blowing down the pressure pipe should quickly prime the engine. If you use clear fuel tube, you can easily see the fuel travelling down the tube into the carb.
Another interesting thing you can do to check the carbs needle settings is the 'blow test'. Disconnect the fuel line from the carb, and put a spare piece of tube onto the carb. Blow down the tube, with the throttle in the closed position. Assuming all is well, you can feel resistance as you blow and can hear a slight hiss. Manually open the throttle as you blow, and you should be able to hear the hiss get louder and the resistance should reduce until you hit full throttle.
This can highlight some typical carb related problems, such as needles that aren't set correctly, blockages in the carb - such as dirt etc and O-ring seal type problems too.
Horatio is offline
